Centralia or Bust! ......Delilahs build
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
I found my self adding coolent occosionaly but didnt think much of it( or didnt want to think about it) Finally a month or two after I first noticed I ran a compression check. It came out 200,190,200,195,192,200 I was pretty happy with this. Then I ran the leak down test. Cylinder 1, 150psi and holding. 2 holding, 3 holding, 4......shit! ::bhg:: . 5 & 6 the same. Its a pretty slow leak through all 3 cylinders and I know the head was torqued to factory specs as it was a toyota crate motor, Ya big $$$ for the last owner.
First I decided to give a retorque a shot, I think out of curiosity more than hope of any fix I would feel comfortable with. I took it to 70, just to see what if would do. Ran the leak down again; 1-still holding, 2-still holding, 3-still holding, 4-now holding, 5- still leaking but slower, 6-now holding. So it sealed 2 of the three cylinders but 5 is still leaking. its slow enough It would definatly be drivable but Im just going to go ahead and get it overwith now. So I guess I have a fall project. So my rebuild begins and with it come the questions.
1. How hard is it to get the tranny off? I really dont want to pull both like the tsrm says. On my budies swap we left it on but only because we already had a good motor and tranny ready to go
2.What gaskets would you recoment? Commetic, or HKS? what about intake, exhaust, thermostat housing, cam seals ect. Toyota is pricy and ebay is dirt cheap, both are discouraging. Are any of the ebay kits worth even looking at? What about felpro? definatly cheaper and the exhaust manifold gasket we threw in my little bros car looked pretty good?
Now for the good stuff ....PICS!
Heres a few shots of my incredibly packed shop, The worst step in this project is going to be making room. The benz in the back is definatly going OUT!
Ya thats a 67 mustang in the back ( Future project) and a 65 comet caliente under the cover. Wheres waldo, can you find the R154 in this pic
My motor as it currently sits
The parts shelf
This engine once made well over 600 ponies on the dyno, with and automatic behind it!!!
Can you tell Delilah's a little crammed at the moment
Heres the downpipe I just fabed up, at the moment the flanges are only tacked on so it could be test fitted. I also still have to splice in the flex section.
Me and my bros Cars
The R-154 is beside the welder. What did I win?
I'd pull the tranny with the engine and then take it apart, but that's just me. Good luck.
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
I agree with Suprahero, it'll be easier to pull the tranny while the motor is still attached, although I'd lift the car up a couple inches to make sure it clears. How many cars do you have? I see atleast 4, and not 1 looks to be working (2 confirmed).
Adam
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Total I think we have 2 Trucks 3 if you consider a ranger a real truck. 2 mustangs, 89 & 67, 2 supras (me and my bros). The caddy (moms car), a POS sable, The benz, a 66 merc park lane and the comet (me and my bro again) so 16 in all, ya we should start a car lot. 9 out of 12 run which is what 75%. At least its passing:icon_bigg . I was hoping I could just drop the trans and pull the motor but if both is easier I guess I go with that
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
The up side is we have just about every tool you could ever need, or never need as well for that matter:icon_bigg
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Ill probably pull the trans with it, it sounds just as easy and then I can give it a look over too. So any oppinions on what gaskets to use??? Also Is it worth it to swap out the oil cooler? I'v heard of a few people who have gone to aftermarket ones or put an RX7 oil cooler on?
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Finally have a little room to breath, the worst part is you would never guess how many hours of clean up went in to this. Still Looks like a mess
My downpipe fits about as close as you could ever hope for so I was pretty satified there. Tucks up tighter than my bros RT
Also got a good start on tearing the front end down
More updates to come. Next on the list are new intercooler, oil and power steering cooler mounts. Along with new IC pipes and a custom accordian hose.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Some un expected parts showed up at my door today
I only ordered them 3 days ago, and they already got here
I picked up a few oil coolers at the wrecking yard today. The large one is Idendical to a B&M stacked plate cooler and measures 11X11
which should barely fit with my new intercooler location.
This is the only issue with it
The ports are quite a bit smaller than the 1/2 inch lines I will be running but the cooling capacity should be more than enough.
Im debating on wether I can just live with this as it saves me $70. Or will it cause problems having ports that small???
Any input would be greatly appreciated here. Good enough or spring for the B&M ...66 8.5X11 cooler???
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
I finally have my intercooler in place, haven had much time to work on it and when I have it seems like everything takes twice as long as I inticipate. I just have to drill a few more holes in the top mount. Then its on the the bumper support and designing new IC pipes.
The cat stock cat is getting replaced with an RT one
I also did some modification to my Power steering Resivor bracket, It now sits about 2-2.5 inches closer to the block. This will give me more room to rout my intake.
BEFORE
AFTER
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
So I finished the top mount this after noon, check it out
I also pulled my exhaust all the way off. Looks brand new, not a spot of rust on it. I dont even want to know what the prev owner dropped on a new oem exhaust.
My ARPs finally showed up as well. Only took 5 weeks to get the right ones
The PS bracket doesnt touch it so it wont interfere with setting my timing. As for having a cps go out I have 3 working spairs so Im not too worried, and why would people want to go back to a distributor???
Jaguar
Permanent Ban
Apr 4, 2005
489
SoCal
www.supramania.com
hey there Delilah
what's it like in Spokane city?
I'm a thousand miles away
but girl your parts they look so pretty
yes they do.
bird cage can't stop the shine on you
I swear it's true.
Hey there Delilah
Don't you worry about your pistons
your boy G-C checked compression
long before you started missin'
Close your eyes
A little work and you'll be fine
G's by your side
Oh it's just a B.H.G.
We've got an M.H.G.
emiliorescigno
1,199
Woodbury, MN
^^^ That is awsome...
But sometimes it sucks having an interesting or catchy name...I have no idea how many times I've been asked if I've seen A Night at the Roxbury
