Can you put a 6-speed trans in a MA70 Chassis ?
Johnysupra
Rhenerie
Nov 7, 2007
125
Michigan
rhenerie.spaces.live.com
I am doing this right now :). It takes some modification but yes its possible.
Also you'll more then likely want an aftermarket Gearset as the lowest you can get stock is 3.73 and the V160 has a very different gearset then W58s or r-154s. 3.53 and 3.06 are both available aftermarket and will fit the MKIII pumpkin.
Also your shifter will not be in quite the same location.
milisakeracing
228
Kalamazoo, MI
1uzsupra.com
Johnysupra, where at in Michigan are you? I would love to stop by sometime to take a look at the swap first hand!
Johnysupra
Rhenerie
Nov 7, 2007
125
Michigan
Im Downriver about 20 mins from detroit in Brownstown/romulus. I have no idea where you are lol.
Edit: Just map quested. You are approximatly 161 mile away ! :aigo:
milisakeracing
228
Kalamazoo, MI
1uzsupra.com
lol, I do make occasional trips to the Detroit area for my job. Next time I am headed over that way I'll PM you.
TRACKMKIII
464
Atlanta,GA
What modifications are needed because I have a 6 spd that I got from work and I would love to stick it in my car!!
Johnysupra
Rhenerie
Nov 7, 2007
125
Michigan
starscream5000 said:
IIRC you'll have to modify your tranny tunnel and make it larger, am I right Jonny?
Yeah pretty much, its not that the V160 is much larger with a W-58 or an R-154, but it doesn't taper down at the tailhousing. its pretty much a big square. So the tunnel just needs to be persuaded to like the new tranny with a hammer.
Don't forget the JZ part to :) 2JZ FTW!!
2jzmk3
Guest
suprarich said:
I second that. Sean says it was an easy install and not hard to shift at all.
yea it was fairly easy. but i have the resources to make it a easy swap. one of the hardest parts was making the shifter cage to work.. i have a 3.73 rear end in there now, and to me it wasnt much of a difference from the 5spd.
im glad i went with the 6spd since i will no longer have clutch/tranny problems.
i just got a 3.54 gearing from Jawsgear to put in mine, so it should be a little better. he may have more, you will have to contact him..
here are a few pics...
SupraMario
I think it was the google
The Farm
Johnysupra said:
That all depends how tall you are. i am 6'1 and i felt like i was reaching way out for the W58 shifter. But if your short it might be an issue.
Truth be told :biglaugh:, 6' 4" here
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
i just got a custom 3.54 from Jawsgear to put in mine, so it should be a little better. here are a few pics...
Sean you are my hero!!!! time to save more money!!!
