I am sure 7M, 1J, and 2J are all similiar so here I go. My car is a 1J but my power steering resoirver can not go where it originally was. I figure why not move it towards the front of the car to make it cleaner look in the end but my problem now is the bottom ps fluid feed is lower then the intake feed on the ps pump itself. Its about 1-2 inch lower then the ps pump intake feed. Would this interfere flow or will the constant pressure coming back from the rack push fluid still?
This is where I want to move it to. As you can see the bottom port is about 1-2 inch lower from the ps intake feed.
