Can anyone find a 1 piece ebay driveshaft?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
chris89 said:
there's a shop here in my town that can do the same, How much did it weigh after it was done?
its weight is less than a two piece but thats almost a given heh you dont have the center pieces
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
SuperSupraKid said:
i would go with a good company that has a reputation of selling good driveshafts. i wouldn't look at ebay from buying such an important part for the car. i wouldnt want the thing to fall apart while racing.
IIRC, Jawsgear sells his DS's on ebay. But, you can go through him, driftmotion, or suprasport to get a Jawsgear DS.
Another thing people aren't taking into account when discussing 2 piece V's 1 piece is that the Centre bearing weight needs to be subtracted from the equation as it's neither rotating or supported by the Shaft in use (think sprung/unsprung weight in suspension terms)
In real terms there is very little difference with the 2 piece having certain benefits that are important.
Fuzz420
Are U Here 2 take My Baby
when i needed mine i just pm'd him on the board and he took good care of me.
iirc, dont you have a custom 2 piece steel d/s?
p5150
ASE and FAA A&P Certified
Central Idaho
Yeah think about the width of the DS and then the torque required to overcome the difference in weight depending on gear ratio.
4" width? = .3 ft/lb torque for every lb of weight on the DS at a 1:1 ratio
so in the lower gears it makes even less of a difference. At a 3:1 ratio you would have to shave off 10 lbs to gain 1 ft/lb of torque
Fuzz: Yep a very custom 2 piece.....
My point is everyone that raves that a 1 piece is xx lbs lighter is mistaken as you can't factor in non rotating or weight supported by the chassis into it.
It's 99% placebo effect the other 1% accounted by either a worn CB or the Rubber bond in the rear section failing and causing the shaft to be out of phase which will rob power.
5150: <nodding> Yep PMoI at work!
f00g00
586
Kuwait
Yes I think a custom 2 piece would be more to my liking. I wonder though if a driveshaft shop can balance the two pipe with center bearing combo together as it would have to be done as a whole unit. Getting rid of the rubber bond and two pipes on the back would surely be nice.
I had a shop here make me a one oiece but no one here can balance it so I took it off. It vibrated at around 70 mph and got worse the faster I went but there was an improvement in performance. Acceleration was crisper.
How much weight can be shaved with a custom 2 piece there IJ. ?
