Can a 89+ r154 be used with my 87 supra?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i'm gonna buy a r154 from a 89+ supra with abs and my 87 doesn't have abs. can i use this trans for my supra? i've been told that if i use this 89+ trans that has abs in my 87 i have to do some sort of mod cuz of the abs. does any one know anything about this? let me know what you guys know
thanks, toua
mkiiSupraMan18
Needs a new username...
United States
I've never heard anything about that... I also don't see how a manual transmission would effect the ABS in any way.
So yes. It will work. No mods needed.
92nsx
2,957
Clearwater, MN
YES, it will bolt right on, and it will not affect the ABS.
The ABS has nothing to do with the transmission. ABS is for the brakes ;)
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Uhm Lol? There is a ABS plug that is on the manual trans it says, Anti-Skid ) it's the the right side, ABS HAS to do with the trans as well.
92nsx
2,957
Clearwater, MN
The two plugs on my R154, one for reverse switch, and one for (what I thought) was neutral switch. But reading the TRSM yes, you are correct it a rear speed connector (w/ A.B.S.) not a neutral switch.
To answer the original question again, it is still yes, you can swap/switch the R154 from the 89 into the 87
side note: Holey post whore 92teal.:sarcasm:
figgie
Twin Cities, Minnesot-ah
SupraMario
I think it was the google
The Farm
figgie;1155796 said:
Rob,
Just an FYI
In the MKIII Supra, the ABS rear speed sensor is tied into the R154 transmission.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=BR&P=68
So if he did have ABS. It is a plug away from working :)
-Figgie
Ding ding, DO NOT forget to either plug that RSS hole up or get the RSS. Or you will just be up chucking trans. fluid threw it. Ask me how I know this.
The plug is right above the fill plug, and if the transmission is a bit dirty, its easily missed.
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
Naw post whore would leave useless information, or misleading, I am sure I got you back on the right track there.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Oh ok. Makes sense now. For some reason I was thinking we had 2 rear wheel sensors and then the one on the trans.
