Camshaft Bearing Caps Scored Up
TurboWeenie
7M-GTblownheadgasketE
Jul 22, 2007
32
KS
I took my camshafts out today to find that the bearing caps and where the cams rest in the head were rough and scored up. The cams look ok, but the aluminum head and caps do not. For the recorded, the head is a remanufactured one that the previous owner had installed about 15,000 miles ago. I'm wondering if they might not have cleaned the head out very well when it was put on, and some shavings were left in there.
What else could have caused this? More importantly, what can I do to mend the damage?
Thanks
-Ryan
TurboWeenie
Jul 22, 2007
32
KS
GrimJack said:
Chances are this is perfectly normal. Every set I've seen to date looks scored. As long as they turn properly, it's never been a problem.
My cam caps and journals feel pretty rough to the touch. I can see irregular scratches and scoring in them, and in a few places it looks like there are some metal deposits, shavings perhaps. Does this still sound normal? The camshafts turn ok, but I wonder if they are turning as easy as they ought to. Any insight is appreciated.
-Ryan
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
The cam caps had a layer of soft babit-like material on them when new. This wears down over time. Light scoring is normal, check the tolerances per TSRM spec to see if everything is still in tolerable ranges. If not, you will have to have them resized most likely.
Rodknock also kills these suckers quick too, which may be the reason yours are scored bad (according to you). Plastigauge them and report back.
TurboWeenie
Jul 22, 2007
32
KS
All pictures are off the intake side, where the scoring was the worst. The scoring was also worse towards the front of the cams.
-Ryan
Tim
regular member
Oct 16, 2006
272
CA
I have had a lot of motors apart, and I have never seen cam caps with scoring that bad:aigo: Did that motor make noise? Have you checked your rod and main bearings?
Kai: You could but it would cost a fortune as the head has to be stripped of all ferrous parts welded straightened line bored/honed reheat treated then all new guides and seats fitted then surfaced.
It's a huge job and a new bare casting is cheaper.
(ask me how I know this)
Kai
That Limey Bastard
Aaah i see. What about the cam on its own then? :)
Just asking as i'm intrigued as to what measures are feasable on buggered heads...this is one of the first DOHC heads i've ever had, previously its either been Ford CVH, VW 8v or Ford OHV Cologne/Essex V6's
