Cam Gears Three little bolt things
ThirstyMKthrice
114
Austin, TX
I was puttin the head back together, when it was time to put the cam gears on i noticed that the gears had three holes around where the main bolt goes. one gear has a little bar sticking out of one of them. on the other gear there is nothing sticking out. i know that those things that stick out drive the cams. im confused wondering how the heck they got lost, and even more lost when im trying to find them. will i have to buy a whole new cam gear set? it would probably help if I knew what the actual name for the parts are...I went to autozone with the gears and showed them all, even they are clueless. i already expected them to be though lol. thanks everyone
Each gear has the pin. Goes in the center hole.
And yes, you need them...likely have to go to the dealer for the missing one.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
And this is new information?????? :nono:
There's only 1 pin in the back of the cam gear. If there is none, then its useless unless you find another pin (same size) and force it into place so it doesn't come out.
OR you could just buy another cam gear for cheap...i have 2 :naughty:
ThirstyMKthrice
114
Austin, TX
i know people, i know. i already said that I had expected them to be clueless. im no fool. my car doesnt run. i had to use parents car and they are crazy, so i could only goto the nearest place.
i got the pin today, $1.74 Thanks again for the part number
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
ThirstyMKthrice;1033811 said:
well before i came back here i put gorilla glue in the hole. That wont mess anything up will it? The pin is solid.
:nono:
I suggest you take the cam gear off and clean all that junk out now before it causes you or someone else pain later.
