cam gear questions??
Chaos_Performance
Ohio and Mass
i was on www.jscspeed.com looking at fidanza cam gears. they say they are for the turbo. does it matter? will they fit the cams on the n/a? what do u guys run? are they worth getting right now or should i save for something else? all opinions are needed.
thanks
92nsx
2,957
Clearwater, MN
AEM here also.
Need to do some grinding to get them to fit right.
Just need to shorten the bolts 2mm (A thicker washer would work as well)
I didn't have to recess the cover bolts at all.
Freaked me out badly when I fitted these with my brand new head with Ferrea Valves turned the engine and it locked solid (thought I'd hit a piston with the bigger Cams)
AJ'S 88NA
2,419
Florida
mass_jdm_kid;1129941 said:
ok then should i spend it on an underdrive pulley or a harmonic balancer pulley?? any advice
Just don't buy a Onorthodox, they are not dampend, unless you want to hammer your mains.
92nsx
2,957
Clearwater, MN
I am not sure on upgrades for a N/A motor as I am turbo, for what give you the best bang for the buck. Maybe something like a header, full exhaust, ignition system.
Remember engines are huge air pumps, you want ot get more in, and then get it out fast.
Harmonic balancer pulley, but make sure it has the dampier part like an ATI one. The ones you see on ebay that are just a piece of machined alum. are not good unless you have a fully built and balanced engine. I know, I tried one in the past and my 7M lasted about 30 miles. The harmonic balancer absorbs engine vibration without one the vibration needs to go somewhere and that some where is the bearings, which is not good.
amichie
182
sYDNEy
I have the Titan brand that I think are made by Fidanza.
BTW I now have two fitted and I had to file back the cover bolts behind the wheels by about 3mm.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
What exactly is the point of installing upgraded cam gears on anything but a fully built N/A?
Seems like there are many, many, many other areas that could use work/modification way before lightened cam gears. :dunno:
Maybe someone can enlighten me...
*edit, just clicked for previous posts:
jdm_mass_kid said:
and i topped her out today at 110mph. and beat a lude
If your N/A is stuck at an indicated 110mph, cam gears should be very, very, far down on the mods list. ;)
<<Perfectly stock N/A with the exception of an Apexi intake and I can do an indicated 120 with the top off, windows down without much effort. Haven't topped it out, because any more than ~100-110 on public roads is unnecessary.
OP: Read this-> http://www.supramania.com/forums/showthread.php?t=66104
After studying above link, go here: http://www.supramania.com/forums/showthread.php?t=60249
amichie
182
sYDNEy
Mine has BC cams and I use the gears to both tune it for performance and get the bloody thing to idle.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
You can gain some performance with cam gears, the duration of letting air in and letting that valve close can give you a decent amount of power, but with a N/A I would start somewhere else first like a turbo *
