Bypassing the Neutral Start Switch???
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I did a lot of searching and couldn't find a direct answer. Here's my situation...I put a soarer 1jz with the A/T ECU in my 1991 turbo with the R154. Everything is wired right (odom helped me and he did the same wires and his is running).
The car is getting power and everything. But, when i turn the key I get nothing. How exactly do I bypass the neutral start switch (jumper which wire to which wire). Please help me. It's killing me. Thanks guys.
Ken
350
Houston, TX
look at the clutch pedal bracket, and you will see a cylinder with a little button that the top of the clutch pedal contacts whenever it is pressed down.
that is the clutch start switch. just jump the two wires on the harness side to bypass.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
I shouldn't need to do that because I'm pressing in the clutch when I turn the key. My problem is the ecu came from an AUTO and now it in a manual car.
Ken
350
Houston, TX
oh, ok. you will see a big, round 3-wire plug near the starter that has some thick gauge wires.
jump the blue and the white wire I believe.
Ken
350
Houston, TX
that is the plug that goes to the NSW of the automatic trans. jumping the two wires simply closes the NSW circuit, allowing you to start the car. with the key.
you asked how to bypass it, there you go.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Thank you very much ITR and IJ. I will give it a try when I get up tomorrow and hopefully report good news on my Build Thread.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
So, you could crank it without pushing in the clutch? If so, knowing me, I'd have to buy a new bumper if ya know what I mean.:biglaugh:
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
If left in gear while trying to start it. A lil off topic, but I could unplug the switch if I were ever to put in a remote start?
Push the Clutch in Crank motor = trashed Thrust bearings and Crankwalk :(
(with an aftermarket clutch)
Dunno about the remote it all depends on what safeties it needs, the Tremec I just pulled out has a proper Neutral Switch in it for the USA market.
(none of our cars had the clutch switch for anything other than Cruise Control cancel)
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
Yeah they have to make it idiot proof for us, go figure.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
I can't seem to find it. I am using the R154, not the auto. Is it plugged into anything or just sitting there loose since I'm not using an Auto?
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Well, I got that problem fixed. It was a black and black/white wire that I had to connect. So, the car cranks now. But, my fuel pump isn't getting any power. Now I'm stuck trying to get power to that.
