Busted Valve Shim bucket. Should I have made a #2 in my pants?
suprunner
south dakota
I'm currently doing the valve clearance adjustment on my 7M. . While following the various write-ups (flat-head screwdrivers+ magnet route), I busted/chipped a piece off of my #4 cylinder (exhaust side) shim bucket.:: angry :: Each bucket has two small channels (one on each side), and I basically made one bigger. I'm assuming that I'll need to replace this. . .? Will this require me to remove the cam? If so, what do I need to look out for? Will all of the valves jump out at me? Will this make it easier to do the rest of the clearances?
Thank you,
Greg
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Just don't turn the head upside down with the cams out...
The buckets are part number 13751-16010, should be about $12 from the dealer. Or find someone around you with some spares... I've got lots, if you were local you could have 'em for free.
suprunner
south dakota
Thanks! Fortunately, I pulled three buckets with the sixteen shims that I got from a Celica at a U-Pull-it. $6 for sixteen shims and three buckets... I think I did okay!
