Okay, I'm going to more or less clone the "How do I get to 350 RWHP" thread, but looking from my perspective.
The same: Similar goals.
The difference: My stock turbo is in good shape, and I don't want to yank it out to send it for an upgrade.
The "twist": Shipping a CT26 over the US/Canada border is spendy. The best shipping cost I could find on fleaBay was over $55 (Not the best metric, but accurate enough.) Add in the crap that the couriers charge, and it gets downright stupid. I could easily blow half my budget on a turbo upgrade in shipping charges if I buy a "core" CT26 and get it upgraded.
Otherwise that looks like my best bet. Anyone have suggestions as to how this could be done without lining the courier's pockets?
Current Mods: If I don't list it, assume that it's stock.
Intended upgrades:
So the BOSS turbo, with the install stuff that I'd need, is looking to be around the $1600 mark, near $2000 if the dual ceramic ball bearing CHRA is worth it (Faster spool is definitely more attractive) and I can then most likely go beyond the 57 trim level. But it's spendy, and I'm not sure that it'd be money well spent, or if I should spend it on other things. I should be able to recoup a couple hundred for my CT26, as it's still in really good condition.
OTOH, a CT26 rebuild is cheap, and a 57 trim wheel sure looks attractive in possibility. If not for the stupidity of shipping charges, I'd go this way hands down.
I figure that I'm looking at $100 for a core turbo to rebuild, unless I can find something cheaper, but that seems to be about the going rate for something that CAN be rebuilt. Practically all of the ones I can find are in the states. Ship it here, and it's at least $150, possibly $175, given that couriers like to add on brokerage charges. Call it $150.
Now I have to send it to be rebuilt and upgraded. Another $50 in courier fees, and, say, $550 to have it rebuilt. $750 so far. Now it's gotta be shipped here, and this time there will be brokerage charges FOR SURE. Call that $75. I'm now at $825 for an upgraded CT26, and that's being optimistic. I can easily break $1000 with other fees, if there's something really wrong with the core turbo that I get, or any number of intermediate issues arise. Add in the fact that from what I hear, it'd be dicey if I started the process NOW that it would be ready for spring. I REALLY don't want to be adjusting to a bigger turbo when the winter hits.
So... I know it's a wall 'o text, but any suggestions are appreciated.
- ARP head studs (Not really a mod, but it'll hold the head on.) w/ head gasket job.
- All new gaskets and seals. Fresh overhaul this summer
- Lexus AFM
- PTE 550cc injectors
- 80mm / 3" exhaust from the turbo back (Am installing Saturday)
- Cone filter (woo hoo!)
- Koyo radiator
- Driftmotion Spearco replica IC (To be installed)
- 2.5" Al IC piping (To be installed)
- HKS SSQV w/ recirculation fitting (To be installed)
- Walbro 255lph fuel pump (To be installed)
- MBC (Set to 9 lbs for stock CT26 and lack of other installed mods)
Intended upgrades:
- Turbo Upgrade. Something that will spool quick and flow HARD without blowing up my motor. This is what I'd like the most advise on. I'm considering a 57 trim upgrade vs the BOSS turbocharger, or another "bolt in" sub for the CT26.
- APEX'i AVC-R. I don't know if this is "more than I need" but it certainly seems to have the options to go as far as I may want to. For now, the MBC that I have will do the trick, but when it's time to go for more, this is what I PLAN on. Again, if there's a unit that isn't $500+ that will take care of what I want to do, I'd like to hear opinions.
