Brian Crower 7M cams and ignition timing issue
amichie
182
sYDNEy
IJ. said:
Steve: I machined a step in a Damper bolt.
When you find the 50thou lift points do you have to subtract the tappet clearance??
So if your tappet clearance is 8 thou should you degree it at 42 thou valve lift or 50 thou valve lift??
The idea of the 50 thou is to get the cams off the base circle and to remove the ramps so you get a consistant reading without having to add/subtract anything ;) (cams can have very different ramps and this will affect the reading and this is how/why you can have 2 "272" cams that are quite different as the "272" is measured from the base circle and is the "advertised duration"
Quite often a big stupid number so they sell...
amichie
182
sYDNEy
On this video they are degreeing a set of Cr0wer cams in a supra 2jz.
In this case they set the timing up at 50 thou valve lift and not 50 thou lobe lift. I emailed crower and they said use lobe lift. I guess its a case of suck it and see.
Video is very informative except the repeated use of "trick" is a bit annoying, I must be getting old.
http://www.youtube.com/watch?v=_MsqA-C3vGI
I indicate off the back of the bucket so 50 thou valve but I can't see that there's any difference as we don't have a rocker arm or anything that changes the ratio from Cam to Valve..
BLACKCAT
185
BHG
Well I think using the term valve lift is a bit confusing as the 7M engines use overhead cams so the valves actually fall not rise when they come of the seat.
There isnt a lot of room to place the dial gauge on the bucket or shim but the way I see it you would have to preload the gauge to something like 60 thou & turn the crank until the valve opens & the gauge reading falls down to 10 thou.
There's enough room to get a direct reading off the bucket but you need an extended probe on the indicator to do it.
I use a magnetic base and a piece of 3mmx50mm flat that bolts onto the Cam Cover bolt holes.
"Valve Lift" is generic in nature and refers to the Valve coming off the seat irrespective of the valves orientation in the motor ;)
(last motor I can think of that actually had "valve life" was an old side valve from the 40's/50's)
Tire Shredder
569
Oshawa
are the threads on the bolt long enough to reach the crank? when rotating the motor, wouldn't it just tighten the degree wheel more, causing it to bend?
TS: Yep just machined a step on the back of the Bolt so the wheel centres perfectly bolt it down then line the pointer up to true TDC 0 and it's good to go :)
The bigger diameter the wheel the easier it is to read accurately.
Tire Shredder
569
Oshawa
understood, thanks. looks like you can get degree wheels fairly cheaply on ebay. I assume the step is very shallow, less than the thickness of the wheel, so it is held tightly?
Tire Shredder
569
Oshawa
IJ. said:
Steve: Correct it's just a pilot, from memory about 1mm the wheel I have is 3mm.
I hope I kept that old crank pulley bolt. I'll have my machine shop machine a step for me when I get closer to assembly time. Thanks again IJ, you are very helpful.
amichie
182
sYDNEy
Here is a very short update.
I now have the gauge etc set up for degreeing the cams.
So far I have checked the exhaust cam only.
With the cams set up on the centre drive pin and lined straight up then the timing events occur as per the timing card at 40 thou valve lift with 10 thou valve clearance. This should correspond with the 50 thou lobe lift on the timing card.
I haven't done the inlet cam yet. That is a job for Saturday.
BLACKCAT
185
BHG
Is it just me or does that timing card diagram seem wrong to anyone else?:aigo:
@0.05" lift:
The total inlet duration is 220 (180 + 40)
The total exhaust should be 236 (180 + 48 +8) ie opens 48 BBDC & closes 8 after TDC giving 8 degrees of overlap.
amichie
182
sYDNEy
The exhaust 50 thou point is 8 deg BTDC not 8 deg ATDC.
The 10 thou exhaust closing point I measured earlier today is 20 ATDC.
