IJ. said:There are a bunch of variables that will affect the Cam's true 0 point such as ANY machine work done on the block or head, Belt stretch, Pully wear, Head Gasket thickness and so on.
This is why they give you the "220@50 thou" Spec so you can degree them in and when your degree wheel says 220@50 thou you look at the Cam pully and this will be YOUR motor's true 0.
From memory 1mm difference is around 2>3 degrees.
Thanks Ian
My motor has had atleast 2 head shaves and one decking of the block when I rebuilt it earlier this year. These were all absolute minimum though at my request. Shaving head or block or gasket thickness does give cam retard.
It also has just an oem style ACL head gasket with ARP studs for a bit of piece of mind.
Just a little update. I tried retarding the inlet cam this morning about 5 degrees to reduce valve overlap since my adjustable wheel is on the inlet cam. And it started and idled no problems. Looks like this weekend will be spent accurately degreeing the cams.
BTW Ian the front crank pulley on the cressida 7mge appears to be solid and not have any rubber damper. So as long as the drive key is healthy my TDC timing marks should be OK don't you think.
Andrew.
