Brake Calipers
Frank Rizzo
478
Fixing your girl's car
Those are not MKIII supra calipers.
If you want true BOLT ON twin pistion calipers, buy front calipers for a 91 previa with ABS, exact same caliper and bracket only difference is twin piston.
shaeff
Kurt is FTMFW x2!!!!
11
Around
If I remember correctly, there is another Toyota that uses nearly identical calipers to our cars, but twin piston. I'm thinking it's the Toyota Previa, but don't quote me on it. In all honesty, it's not the caliper design that's holding us back the most, it's the size of the rotors- So unless you're going for newer stock brakes, these twin pistons won't make a whole lot of difference...
shaeff
11
Around
Oh, I didn't even look. Ebay is blocked at my job so I didn't even try.
In any case, with brakes, go big, or just keep them stock and in GOOD working order.
figgie
Twin Cities, Minnesot-ah
More pistons won't do anything in our setup. We have a small torque arm (ie the diameter of the rotor is small) so adding more clamping force will do nothing.
