Bolt size for the r154 clutch slave cylinder?
Satan
Tampa
Easiest thing to do is to put a bolt into the hole and make sure that the bolt goes in far enough to not "bottom out" when the slave cylinder is attached. Good luck!
7thousandpiecesMGTE;1552509 said:
Ah crap, you are correct.... m12 bolts would be for a beefy slave cylinder!!! :D I'll try some m8x1.25 and see if I can figure out the length. Thanks guys.
I'll post it up for future reference when I figure it out.
LOL wouldn't ever fall off ;)
