Bluechulappa's 89Turbo restoration
Bluechulappa
839
hOUSTON
www.houstonareasupras.com
Wow so I had a massive fuel leak coming from the injectors. Took them out tonight and most is not all of them were shredded up looking and had cracks all around. I dunno why I didn't replace them when I had stuff apart? Live and learn I guess.
Would having that big of a fuel leak cause the car to idel rough, hesitant start ups, and a loud hissing noise? Cause we isolated the hissing noise to the area near the oil cap, injector 1,2 where leaking very bad. Checked all the hoses and the fuel leak was the only thing I could find? I'll post the pic up later!
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
Are you talking about just the seals and the grommets, the o-rings on the top will cause a fuel leak if bad, the grommet on the bottom can cause vacuum leak. If you have them installed correctly, you should be able to rotate them a little, lightly lube the o-rings when you install.
Bluechulappa
839
hOUSTON
I replaced the grommets...
Horrible huh
bryanintexas
aaarrrrrggghhhh!!!!!
Apr 4, 2005
605
spring, texas
Wow, I didn't think of that as being a place for a vacumm leak......
Bluechulappa
839
hOUSTON
Hmm. I just took my fuel rail back out cause I was wondering if thats the place of the leak? I replaced the grommets that go into the head.... but... your saying o-rings will cause fuel leak? I think I'll just go back to toyota tomorrow morning and get new o-rings and the gromment things that go against the fuel rail. Better safe then sorry. I think they had them all in stock
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
If you install them with the o-rings dry it's not hard to "pinch" or tear an o-ring. Pull them out of the rail, and look for a little tear in the o-ring. I have to say I've never seen an injector leak externally.
Bluechulappa
839
hOUSTON
Got all brand new moldings for around the car! I'll be selling the old ones if anyone is interested. They are in good condition. Plus all the windshield black moldings. Waiting to save up money for a new front bumper, a little bit of body work and a brand new paint job!
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
Pics of new moldings please... No teasing.
