Blah blah blah, 9/11 conspiracy, a plane has hit the Pentagon? What do you think?
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Yes, I understand your view :) but this was not a plane that was trying to land safely (like most crashes) It hit a solid object head on much like the vid *Rakkasan posted. I am actually suprized the pieces are as big as they are. :)
It's not just the plane, but all the "stuff" inside that has mass that causes the damage.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Yes, Much in the same way that a soft copper shaped charge can cut through steel like butter.. The soft metal takes on properties of a liquid to a point.
I think it is the same way a waterjet CNC machine can cut steel at high speed/pressure using only water..
figgie
Twin Cities, Minnesot-ah
basic fluid dynamics
it takes ALOT to break the liquids tension. At high speed that works to the advantage of the liquid as that very tension acts as the "knife" to slice through just about everything.
Primacord if I recall can cut through about 3 feet of steel without any issues. And that is a tiny little cord that is about 6 feet long.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
A flexible woven cord with an explosive core which detonates at an extremely fast velocity of over 20,000 feet per second.
Also known as "det cord"
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Why is that? the black box recorders supposedly can withstand extreme crashes as they have proven time and time again. They also have homing beacons in them so when a plane crashes they can be found as quickly as possible. Why the hell do they just disappear
They did not disapear, they were recovered intact at 4am on September 14th 2001
http://www.firehouse.com/terrorist/14_APboxes.html
The tapes were not released to the public however. I can understand why..
figgie
IJ. said:
Really interesting discussion guys!
I'm impressed that our guys are so much more mature and show respect for each others point of view!
be quite you down under kiwi with cheap LPG!!
<-- Votes for annexing of Australia to the US!! ;)
Fuzz420
Are U Here 2 take My Baby
John Hancock Tower, Chicago = 384, 000, 000 kg
Sears Tower Chicago = 440, 000, 000 kg.
Taipei 101 = 700, 000, 000 kg.
Petronas Twin Towers = 350, 000, 000 kg. (each)
Both twin towers were built to be as light yet rigid as possible so as to withstand the extreme forces of the 100 + mphs. The buildings load was carried 60% by it's core and 40% by it's perimiter steel columns. The perimiter carried the lateral load to resist the wind where as the core carried the gravity load.
Now check this....the weight of structural steel used in each Tower is generally reported to be 96, 000, 000 kg and the weight of concrete is said to be 48, 000, 000 kg per Tower.
The Aluminium panels were reported at 2 million kg
The wallboards were at 8 million kg
Adding those together the skeletal structure clocked in at 154 million kg per tower.
More mass is added to the figure when you factor in the utilities, and other fixtures.
Because there is no actual report that fema nor nist gave for these figures the only thing we can really do is take a guess at it.
Plumbing, electrical and telecom would each add about 5 million kg giving us additional 15 million kg. Adding that to our structure we get a figure of 169 million kg which constitutes as the buildings dead load.
When we populate the buildign with office furniture, supplies and people then more mass is a dded.
As you can see this 169 million is only a 1/3 of the reported total weight of the building. Factoring the live load of people, office furniture and other objects in the buildings...the live load will rise dramatically and the building could top out to over 300 million kg. but it's still 200 million shy of the 500 million.
The sears tower was larger and taller than either tower and it is also a tube within a tube steel building yet it weighs less?
John Hancock is 100 stories and is built as tube within a tube just like the twin towers composing, of steel, aluminium and glass, yet it clocks in at 384, 000, 000kg. (live load included). And the building was not built of light weight steel like the twin towers so it was in fact heavier.
WTC is similar to John Hancock in terms of it's concept so it's fair to consider the two buildigns will be close in mass value. In any mathematicaly equation if one variable is off by just a mere fraction this throw s ur result off. Greening was off by 200 million kgs....so his values for the k.e. and g.p.e. would undoubtedly give us those high values with such a large mass.
What upsets me guys is not enough detailed information on the towers construction is widely distributed....and the only figures we can really work from are fema and nist....because the buildings plans and structural elements are deamed national security. If they have nothing to hide then why can't independent scientists get copies of the buildings designs? They are already destroyed and they won't be used again so why the secrecy?
here is greenings direct reply: ~Lyte Trip
"You make some very good points and I will try to address them as best I can. First let me say that the article you are quoting was written a while back and I have done some other stuff since then that adds and expands on my original work. That original work was therefore a first attempt to see if the Towers could theoretically have fallen by a pancake collapse. The answer appeared to be YES! But as I looked at more videos and read some of the stuff I am sure you have also read, I now say that the collapse of both Towers was more complex than my simple model, as I will explain in a moment. First, on the mass of the Twin Towers, I have recently done some checking into that and I see quite a spread in values.... Some references simply give the potential energy, which implies a mass through the equation 1/2Mgh, (factor of 1/2 because average height fallen is h/2)...... For example, FEMA give the PE of one Tower as 4 x 10^11 J which implies a mass of 196, 000, 000 kg, but the May 2002 issue of Civil Engineering Magazine to be found at ASCE.ORG gives the PE as 3 x 10^12 J implying a mass of 1, 472, 000, 000 kg! The figure I used, and I think it was similar to the value quoted by Profs Eager, Bazant and Kausel ( all engineering profs who have written articles on 9-11) is somewhere between the FEMA and the ASCE.ORG number, let's say about 500, 000, 000 kg....... But I would really like to see a detailed breakdown of the mass, because I am not sure if any of these numbers are correct!"
(so he backs away from his own conclusions by calling them "old"......admits he is not sure about the mass and that GQ makes good points......and then admits that he is "adding" to this flawed paper instead of revising it!) ~Lyte Trip
Ti= 1/2 (330, 000, 000/110) x (8.5)2 = 108, 375, 000 J that is 59, 693, 181.82 J less than the figure Greening got!!!
If we use the dead load this is what we get: 55, 501, 136.36 J!!!! That's less than the difference in energy of the live load vs Greenings magic number!!!
KE for the combined floors: Ta = 1/2 (330, 000, 000/110) x (8.5/2)2 = 27, 093, 750 Joules
Now let's calculate that energy for the floor collapse.
The KE before impact is show below
T1 (wtc) = 14 X 1, 083, 750, 000 = 1, 517, 250, 000 J
T2 (wtc) = 29 x 1, 083, 750, 000 = 3, 142, 875, 000 J
The KE lost as heat is calculated as follows
Q (WTC 1) = 1/(1 + N) x Ti (WTC 1) = 14/15 x 1, 083, 750, 000 J = 101, 150, 000 J
Q (WTC 2) = 1/(1 + N) x Ti (WTC 2) = 29/30 x 1, 083, 750, 000 J = 104, 762, 500 J
The precent of energy lost as heat for each tower:
Tower 1 = Q/T1 x 100 = 6.67 percent
Tower 2 = Q/T2 x 100 = 3.33 percent
One thing Greening forgot to mention was how much energy was also lost as sound and that is something that can't really be calculated unless decible readings were taken, then we can calculate the energy lost to sound as well.
OH before I forget to mention it....t he weight of one floor is NOT 4, 360, 000kG, it is in fact 3, 000, 000Kg and that is our live load!!!! the dead load is actually 1.56 million Kg per floor.
Moving on.....
If we now assume, as previously
discussed, that the yield strength of the core columns is about 6.7 times higher than the
yield strength of the exterior columns, we estimate that an additional 3.60 ? 108 J are
required to collapse the 47 core columns supporting each floor. Thus, based on T.
Wierzbicki et al. calculation, we estimate a total of 6.29 ? 108 J of impact energy was
required to collapse one WTC floor, a value that is remarkably clo se to Baants estimate
of 5.0 ? 108 J for the plastic energy dissipated by the collapse of one floor.
Greening says 62, 900, 000, 000 J is required to collapse one floor of the WTC Towers....
Now as you can see from my calculations.....it isn't even close to that!!!
The maximum kinetic energy of each WTC tower collapse occurred at the end of
the 1st stage of the two-stage collapse. At this point in time the falling material, consisting
of at least 80 floors weighing about 370, 900, 000 kg, was moving at about 50 m/s. We will therefore assume that each tower had a maximum kinetic energy of
x 370, 900, 000 x (50)2 J or 4.6 ? 1011 J.
Again because his mass is wrong....this throws everything off again...
80 floors equates to 72.2% of the building....so we multiply that by the mass of the building and we get the weight of the 80 floors.
The fig ure we get is 240, 000, 000Kg!!! Which is about 130, 900, 000 KG difference!!!!
so let's do the kinetic energy
1/2 x 240, 000, 000 x (50)2 = 30, 000, 000, 000 J.
Greening Got 46, 000, 000, 000 J so we have a difference 16, 000, 000, 000 J of energy here!!!
From photos of the debris pile produced by each WTC tower collapse it is evident
that steel columns and trusses, aluminum fasciae, glass windows, gypsum wallboards and
other construction materials were all fractured and pulverized to varying degrees during
the collapse events. Thus only a fraction, f, of the 4.6 ? 1011 J of kinetic energy, was
available to crush the WTC concrete. For the present calculation we will assume a value
for f of ~ 0.75, giving 3.5 ? 1011 J of available kinetic energy.
Lets consider the beginning of the 1st sage of the collapse of each tower. For
WTC 1 we will take as an example 14 floors, and for WTC 2, 29 floors impacting the
floor below with a maximum velocity of 8.6 m/s. It follows that the kinetic energy on
impact was ? 1 4 ? (510, 000, 000/110) ? (8.6)2 joules = 2.4 ? 109 J for WTC 1, and the
K.E. was ? 29 ? (510, 000, 000/110) ? (8.6)2 joules = 5.0 ? 109 J for WTC 2. If we
assume 50 % of this energy was available to crush concrete, we have 1.2 ? 109 J available
for WTC 1, and 2.5 ? 109 J available for WTC 2. This is sufficient to crush the concrete
on the impacted floor to 175 ?m particles.
Some have suggested that even if Greening used an incorrect value for mass that his calculations still hold true and that a smaller mass would still lead to a collapse. This is not true as demonstrated here:
Tower 1: X 14 ? (510, 000, 000/110) ? (8.6)2 joules = 2.4 ? 109 J for WTC 1, (Greening)
1/2 x 14 x (330, 000, 000/110) x (8.6)2 = 1, 517, 250 , 000 J Almost 1.5 billion J Difference!!!!
Tower 2: x 29 x (510, 000, 000/110) x (8.6)2 joules = 5.0 x 109 J for WTC 2. (Greening)
As a scientist Greening should know that rounding off numbers skews your results...in fact the correct figure for that calculation is 4, 857, 170, 455 J
1/2 x 29 x (330, 000, 000/110) x (8.6)2 = 3, 142, 875, 000 J
a difference of 1, 714, 295, 455 J!!!!!
Now if 50% of the energy is required to crush the concrete this is what we'll get for both towers:
Tower 1: 1/2 x 1, 517, 250, 000 J = 758, 600, 000 J
Tower 2: 1/2 x 3, 142, 875, 000 J = 1, 571, 437, 500 J
Consider now the newly formed mass of (14 + 1) floors of WTC 1, and (29 + 1)
floors of WTC 2, impacting on the floor below. Because of momentum transfer, the
impact velocities are slightly lower than the 8.6 m/s impact speed for the first floors hit:
8.1 m/s for WTC 1, and 8.3 m/s for WTC 2. The maximum kinetic energy prior to impact
is x 15 x (510, 000, 000/110) x (8.1)2 joules = 2.3 x 109 J for WTC 1, and x 30 x (510, 000, 000/110) ? (8.3)2 joules = 4.8 ? 109 J for WTC 2.
This is essentially the same result as the previous impact calculation and the kinetic energy released is therefore also sufficient to crush the concrete on the impacted floor to 175 ?m particles.
This is where he goes wrong!!!! HE says it requires 190, 000, 000, 000 J to crush concrete to 100 micro metre particles!!! Guess what; we don't have that enery!!!!
Let's do it using his 15 and 30 floor results
for 15 floors I got: 1, 625, 625, 000 J
for 30 floors I got: 3, 251, 250, 000 J
Greening got: 2, 300, 000, 000 J for 15 floors and 4, 800, 000, 000 J for 30 Floors.
See the big mistake!!!!
Frank Greening:
"Finally, we will cal culate the energy needed to crush all the concrete in a single
WTC tower (= 48, 000, 000 kg) to particles of a specified size. As we have noted before,
the energy required to crush all of the concrete in one tower to 60 ?m particles = 3.2 ?
1011 J which is only slightly less than the 4.6 ? 1011 J of energy available. However, the
energy required to crush concrete to 100 ?m particles is 1.9 ? 1011 J, which is well within
the crushing c apacity of the available energy. Hence it is theoretically possible for the
WTC collapse events to have crushed more than 90 % of the floor concrete to particles
well within the observed particle size range.'
Considering Greening's results are already skewed we know that the energy calculated is not sufficient to support the gravitational collapse of the towers.
everything is ok now, your government is in control
_________________
MSNBC archive: hijackers trained at US bases:
http://www.prisonplanet.com/alleged_hijackers_may_trained_us_bases.html
FBI agents told to "back off" from investigating al Qaeda months before
9/11: http://www.guardian.co.uk/Archive/Article/0,4273,4293682,00.html
Time.com "9/11, an Inside Job? How the boxcutters were preplanted"
http://www.time.com/time/nation/article/0,8599,175953,00.html
MSNBC Slate: Boxcutter story a myth:
http://www.slate.com/id/2088092/
USA Today: NORAD ran drills simulating 9/11 like attack
http://www.usatoday.com/news/washington/2004-04-18-norad_x.htm
Bush forced EPA to lie about 9/11:
http://www.cbsnews.com/stories/2003/08/09/national/main567489.shtml
Mineta testifying about Cheney's suspicious 9/11 behavior:
http://www.youtube.com/watch?v=bDfdOwt2v3Y&search=mineta
MSNBC: Osama a former CIA asset:
http://www.msnbc.com/news/190144.asp
Pakistan funded 9/11:
http://www.guardian.co.uk/comment/story/0,,1266317,00.html
Two 9/11 hijackers lived with FBI informant:
http://www.cbsnews.com/stories/2002/09/09/attack/main521223.shtml
Here's a VERY important Washington Times article showing how an FBI agent went to her superiors with documents from pre 9/11 that al Qaeda was going to strike with hijacked airlines:
http://www.washingtonpost.com/wp-dyn/articles/A60651-2004Apr8.html
FBI agent blocked by higher ups on uncovering plot:
http://www.latimes.com/news/printed...1,1,5398407.story?coll=la-headlines-frontpage
Fuzz420
FBI translator Sibel Edmonds says that if the truth ever came out about 9/11, there'd be some very high people in the US government behind bars:
http://baltimorechronicle.com/050704SibelEdmonds.shtml
Top FBI agents told to back off from investigating al Qaeda hijackers months before 9/11
http://www.laweekly.com/news/news/another-fbi-agent-blows-the-whistle/3706/
FBI agents drop 9/11 bombshell:
http://www.time.com/time/covers/1101020603/memo.html
FBI agent robert wright warned the WTC was going to be attacked soon based on evidence field agents found, and that a terrorist attack was imminent, but he was told to shut up:
http://www.newsmax.com/archives/articles/2002/5/30/161204.shtml
FBI agents say government is protecting terrorists, covering up 9/11:
http://www.judicialwatch.org/2469.shtml
#3 CIA man says Osama should stay free:
http://www.timesonline.co.uk/article/0,,2089-1431539,00.html
Taliban, UK, Israel, India and Russia warned US weeks before 9/11 a big strike was going to occur:
http://news.bbc.co.uk/1/hi/world/south_asia/2242594.stm
http://portal.telegraph.co.uk/news/main.jhtml?xml=/news/2001/09/16/wcia16.xml
http://www.janes.com/security/international_security/news/jid/jidpromo011005.shtml
http://prisonplanet.com/bush_was_given_hijack_warning_by_british.htm
Intelligence keeping top al Qaeda masterminds safe and protected:
more proof intelligence is providing safe haven for the top 9/11 masterminds and al Qaeda planners:
http://www.time.com/time/world/article/0,8599,300609,00.html
http://www.guardian.co.uk/ukresponse/story/0,11017,751102,00.html
US allowed top al Qaeda and Taliban flee to safety:
http://www.guardian.co.uk/bush/story/0,7369,636763,00.html
http://timesofindia.indiatimes.com/cms.dll/html/uncomp/articleshow?artid=38382324
And of course the US made a deal with Pakistan to have these top al Qaeda flown out in late 2001 to safety:
http://www.msnbc.com/news/664935.asp
CIA used al Qaeda to attack Serbs in Bosnia:
http://www.guardian.co.uk/comment/story/0,,688310,00.html
http://www.nationalpost.com/news/world/story.html?f=/stories/20020315/344843.html
9/11 Families Back 9/11 FBI Whistleblowers:
http://www.washtimes.com/upi-breaking/20050123-072909-2717r.htm
PBS documentary on FBI John O'Neil, who was told at every turn along with other FBI agents to stop investigating al Qaeda, was convinced the US was complicit with Osama and said the WTC were going to be attacked:
http://www.pbs.org/wgbh/pages/frontline/shows/knew/
FBI agents bring about evidence to 9/11 families how much the government knew:
http://www.villagevoice.com/issues/0415/mondo10.php
Finally, for the tinfoil hat people reading this, here is Alex Jones on
his program July 25th 2001...just a month and and half before 9/11, emphatically warning people elements within the US were planning to launch a terrorist attack in NY at the WTC and blame it on former CIA asset Osama bin Laden. In fact he urged everyone watching to call the white house and tell them not to go through with it. For weeks after that he was insistant a major strike on NY to be blamed on Osama was about to happen:
http://www.prisonplanet.tv/articles/august2004/082604alexwarned.htm
United Flight 93 Forum Post taken directy from the flight 93 forum.
With out actuall making my own post, but if you can disprove all these things that i have quoted, yes then and only then will i believe what happened. Out all honesty how dumb does our government think we are.
Have a nice day
*edit they took the site down, it was very interesting to say the least, but the truth can not be suppressed
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
No offense Fuzz, but this is the Pentagon building thread...No one should be doubting that planes hit the WTC and those buildings collapsed.. Most of us watched it happen on "live" tv.
There is no doubt in my mind that we (our government) knew ahead of time that these attacks were a possibility and even a threat before 9/11.
I also agree that the threats were dismissed as "not likely" and this was a huge mistake on our leaders part. Heads should have rolled. But that does not make the attack a "conspiracy" by our government. Just the cover up of the pre 9/11 warnings after the fact....IMO
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
From my post to Joel on the other 9/11 thread
Quote:
Originally Posted by Joel W.
garage: thanks, that helps. :)
the only way i can see the damage is if the plane came in and left wing hit the base of the left side, and the right wing hit the top floors. banked left HARD on impact?? and once a plane is up, its not hard to fly them...try flight sim sometimes.. its easy...
I'm sure its easy, almost like a car. Lol. But the wingspan of the 757 is almost 125 ft. wide. Compared to the 77 ft. high Pentagon, the wing would have dug into the ground. Causing damage to the ground and ripping the wing off leaving a big chunk of wing behind. That did make me think a bit and recheck the specs of the plane. Lol.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
world trade center one and two...and SEVEN, were all taken down with explosives on september 11th.
if the world trade center towers went down because of the fire from the crash and that bullshit pancake theory, then they are the first buildings to go down because of a fire in history.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Dcru: This is about the only way I can see the damage shown in the picture of the Pentagon. This is not to scale, but I am sure it is close enough for this discussion...
TKA: They were the first...
1TuffSupra
Sho' Nuff
Jul 11, 2005
500
Raleigh, North Carolina, United States
s383mmber1 said:
http://members.iinet.net.au/~sperna/omgkool.swf
This video some some amazing footage of MOMENT after the crash.
It compares the crash of the pentagon to other crashed planes. The grass two feet infront of the building was never even touched.
Highly unlikely.
Please watch the video.
did you guys watch this video? it brings up some incredible points. Where did all the security camea footage from all the surrounding businesses go. Plus it has countless statements from witnesses
1TuffSupra
Sho' Nuff
Jul 11, 2005
500
and the first to go down because a plane hit it, even the empire state building didnt go down when a b52 ran straight into it and we all know they are big as hell. Eye witnesses said that the fire from the explosion traveled all the way down the stairwell to the bottom floor. Here are the dimensions.
b52:
Length 160.92 ft (49.05 m)
Wingspan 185.00 ft (56.39 m)
Height 40.67 ft (12.40 m)
757:
Length: 155 ft 3 in (47.32m)
Wingspan: 124 ft 10 in (38.05m)
Height: 44 ft 6 in (13.6m)
