Billet Alternator and AC Bracket Setup!
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
As for belt tension, I have never used one since I ever put my first FFIM on. You can manually pull the belt tight enough and then just lock the bolts down with locktite and never had an issue. I do always dress the pulleys with belt dress before I put a new belt and kit like this on.
So what do you guys feel would be a reasonable price for the kit. Keep in mind a billet bracket to just put the alternator where the AC is runs about $100-$125 for one piece. This kit is 5 billet pieces!!!
Thanks,
Seth
oldsking
789
Chapel Hill, NC
Damn I thought billet parts were cheap to make especially if you do them in groups haha I was hoping for not much more then 100 but thats just me :)
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Haha, obviously you don't know anything about making billet parts! Lol Anything made on a $40,000(used, $90,000new) machine that uses $20,000 worth of programing software running it is not going to be that cheap! It is $50 in material alone for all the parts in the kit! Maybe I need to make a video that shows all the effort it takes to think up, design, and make a product like this!
Seth
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Seth
oldsking
789
Chapel Hill, NC
Haha ahh when you throw figures out like this then I can understand the reason for cost :) I knew those CNC machines were not that cheap lol
Apr 6, 2005
339
Alpharetta, GA
Thanks,
Seth
I don't think you're doing this because of charitable causes. So, basically, COST OF MATERIALS + LABOR COST = $??? X 1.45 = FINAL PRICE. 45% is usually on the low end of pricing to capture profit and all eventualities.
oldsking
789
Chapel Hill, NC
Seth have you determined what would be a feasable price for the set up? I am awaiting so I know or I may be going with the LIPP and not worry about a/c. Im needing to get a brackt soon though s my FFIM is ready to bolt on.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
HKS_TRD;1804464 said:
Can you post a pic of the breather on the block to show where the alternator sits in relation to it.
Haha I knew you were going to ask that! Send me a pic with what fitting you are going with and I will tell you if it will fit. With a bit bigger belt so the alternator is tensioned to the max you should have no problems getting the the AN fitting in there as long as it is not a straight fitting but rather a 35 degree or what ever would make it come to vertical. I will try to take a picture in a bit.
Seth
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Dan,
Should clear fine. It does not accommodate both alternators although I can slot it easy enough. Are you running the larger alternator? If you have one can measure the hole spacing, CL to CL?
Thanks,
Seth
