BIC Divorced Downpipe Q's
Alec
SP Tuned
Apr 6, 2009
712
Illinois
I'm looking to possibly get a BIC Divorced Downpipe and test pipe and had a couple of questions.
1. Is it worth it to get the re-routed wastegate pipe(partially divorced)?
2. Is it worth it to get the ceramic coating?
3. Is it worth it to get the flex section?
All help is appreciated. Mods are in sig.
Cycoclown
SHAAWING!!!
Jan 18, 2008
131
Vacaville, CA
ive had both the DDP and the full 3inch DP
never had the flex section tho. if its not rerouted it and the wastegate opens sounds like a pissed off possom which is kind of annoying, but its not to bad
all in all. BIC does good work. just make sure u can get the little bracket thing off before u install the pipe. 1 bolt on mine was rounded off so at first i heard it raddling but a nice clamp fixed that :)
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
If they made the re-routed when I got mine I definetly would have gone that route. I didn't like the noise at first, thought it may grow on me, it didn't.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
I hear that if I get a divorced downpipe I will always be hitting fuel cut, would that be true for my car and it's mods?
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
Its possible/highly likely to hit FC on a open DDP, especially depending on the ambient temperatures.. with the rest of the exhaust on you probably will only fuel cut on cold nights (dense air)
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Would getting the downpipe reduce the life of my engine?
no if properly maintained. it opens the exhaust more so it increases boost a couple psi thats why you might hit fuel cut. get a boost controller and back it down a bit if you do.
all in all. aaron does good work. just make sure u can get the little bracket thing off before u install the pipe. 1 bolt on mine was rounded off so at first i heard it raddling but a nice clamp fixed that :)
Aaron who?
Alec
SP Tuned
Apr 6, 2009
712
Illinois
I am still contemplating whether or not to get it re-routed or just release to the atmosphere. If it makes any difference, I have the RSR GT-2 exhaust.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
IJ.;1329718 said:
Personally I'd reroute as the one time you get on it hard will be the time the EPA inspector points his mic at you or the cop is 2 cars over...
Well, in Illinois I wouldn't have to go for emissions. But, how much power do you think I'd lose by getting it re-routed?
IJ: you wouldn't hear it over the RSR :rofl:
As my car is relatively quiet, I'm tiring of my DDP... though I do like it when I get a bit pissed in traffic...
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
im also looking for a ddp, but everyone seems to hate the open ones. ive never actually heard one. also can someone explain to me the advantages of the ddp, i know they make more power but how? im guessing less backpressure, but wouldnt the recirculated have the same backpressure as a normal dp?
Alec
SP Tuned
Apr 6, 2009
712
Illinois
lol, so what are you saying for a RSR exhaust? re-routed or no?
mirage83
457
Georgia
I personally prefer the recirculated DDP's. You get a lot of the benefit of a divorced dp and not as much noise as you get from an open pipe.
The flex section is a good thing to have as well imo, as it helps allow the system to move somewhat, a little insurance from sustaining damage at the turbo and/or exhaust manifold when you bottom out over stuff. Makes it easier when installing the DP as well in some cases.
Go ceramic on your manifold and dp if you can afford to do it and find someone who does quality work. Makes a big difference in underhood temps, and that'll help keep your rubber and plastic pieces there intact longer.
Just my opinions as a relative noob, take them for what they're worth. Good luck with your system whatever you choose.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Poodles;1329810 said:
if you have an RSR, you obviously don't care about noise or drone, so you could go DDP...
I personally like the sound of the RS*R exhaust. Of course, I like being obnoxious :biglaugh:
