put the head back on after cleaning it up, and cleaning the block. installing a new TOYOTA HG, block deck is clean, head is clean.
i put the head on and dropped in the ARP studs and for some reason decided NOW would be agood time to splash some oil on the cams since they looked pretty dry, anyway as i was installing the studs i noticed oil leaking out from between the head and the block. the oil pooled in the stud holes and when i started to thread the studs into the block the oil was forced out and some ended up dripping down the side of the block.
you guys think that might keep the HG from sealing?
