ok guyes sorry for my bad language, im french but ill do my best to explain.
i bought a supra with a 15000km engine rebuilted with arp studs and cometic hg. the car had a bhd on it so i took off the block//head from the car and got it machined to a shop that knows the 7m well.i also bought a 2.0 hks mhg stopper and used the used arp studs with the rest of moly lube.
took everything together then my friend torqued my head studs for me @ 85 lbs. the car was o.k. at idle, but when i was rolling a little it smoke a lot white and some white smoke come out of the hg outside the engine. took back the car in the garage then, un-torqued all studs and noticed that one was at around 50 lbs of torque.re-torqued everything in 4 passes (40 70 90 95) lbs of torque and re-assembled everything.
result: the car is doing the same thing, what could it be :S?
