Battery Tie Down
1TuffSupra
Sho' Nuff
500
Raleigh, North Carolina, United States
Did our cars come with a battery tie down? Mine doesnt have one and after cleaning and re-tightening all the terminals and grounds my car still completely died from time to time as if the batter had been disconnected. So I ended up sticking a towel in the engine bay around the battery to keep it from moving and low and behold the problems with the car cutting out disappeared. But I dont want to do a hack job here I actually want to fix the problem. The previous owner didnt have a problem with this, but he wasnt getting the car sideways like I do either. But I checked on Jay Marks Toyota's site and didnt find a tie down, any ideas as to where I could find one?
Jeff Lange
Administrator
4,922
12
Sunnyvale, CA
jefflange.ca
Yes it came with one, yes it's still available from the dealer, no it's not expensive, yes you should get a new one, it's like $15.
Lots of information crammed into one sentence ;).
Hope that helps.
supra90turbo
shaeff is FTMFW!
33
MA, 01440
that is correct, doom.
i watched a guy fail for that. i almost died laughing.
he drove like 3 hours to get there.
jeff: that's a nice, informative post you've got there. lol
doom26464
Research...research
Saskatoon SK, Canada
siman said:
I use the light weight JDM tite Zip tie method. :biglaugh: works fine...so I havent changed it.
won't be acpeted by a local drag stip they need something solid like metal.
Batteries/Ballast: Batteries must be secured per OEM, or with minimum
of 2, 3/8 inch diameter bolts. (No bungee straps, cords, etc.)
taking right from the tech sheet of the SIR here in saskacthewan.
Had a battery come loose many years ago and hit the fan and explode with plastic and acid everwhere!
Pretty well scratch 1 car as no way know could I get rid of it all and the rust that followed!
Lesson learnt from that was always use a good hold down or a battery box!
csr ma71
rooftop sniper
Apr 2, 2005
254
bay area
www.angelfire.com
I use the factory tie down and the factory plastic piece that goes over the front of the battery. Except I don't know how the plastic piece is supposed to stay on so I used zip ties for that. Hold pretty well with just the plastic piece itself.
