Automatic Transmission Cooler
JesseH
1,153
you already have a stock one built into your radiator, but extra is always good, i am running a fairly big cooler on mine. One of the biggest destroyers for the A340E trans is heat.
Ckanderson
2,644
The beach
B&M make some really reasonable priced transmission coolers in a wide range of sizes, some even with fans (you could wire up a temp activated switch).
I would highly recomend one!
Comes as standard on the B&M fan coolers Chris :)
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i allway's ran a cooler on mine.i hook them up on the return line after the radiator.the fluid will travel through the radiator, then through the cooler on the way back to the trans
