Auto trans differences?
Boosthpy
133
Idaho Falls
Does anyone know the differences in auto transmissions for the supra? My friend ordered one for his n/a 87 and his new one has 4 plugs on the trans (they are grey) and his old one has three.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
from what ive run into the sensors are just different and you have to swap them from your old trans to the one you just bought. if there is an extra sensor you've never seen it might be the abs sensor if you dont have abs or something to that effect
JesseH
1,153
there is an extra sensor depending if you have the ABS or not....and I believe that the speedo gear changes sizes between post and pre 89. There should be one plug for the Neutral start (big round plug coming from the passenger side, you will have a small 3 wire square plug for the selanoids, the one more plug also a square, dont remember the function off hand. the fourth plug would prob be your ABS.
hope that helps
gofastgeorge
944
Texas
Nick M;1010924 said:
The GE and GTE trans are a little different on the inside.
Do they take the same torque converter (NA/turbo) ?
And along those lines, does the Mkiv take the same converter also ?
tlo86
Jul 24, 2005
3,914
Colorado
they use the same torque converter
im interested on how they are internally different... mine did seem to shift different when i went with an n/a trans
i can tell you if the 2j converter will work on a 7m trans in a couple of weeks heh.
JesseH
1,153
the turbo trans has bigger clutch packs in it
Boosthpy
133
Idaho Falls
So here is another question, the plugs themselves look different from trans to trans. One has grey plugs on it and are a little different did they change on board diagnostics in the years. Any insight on that?
8,897
The GTE has an extra steel and friction, larger piston to hold, and that is about it. The later JZA80 went with a little bit more yet.
Boosthpy
133
Idaho Falls
So here are both trans plugs and the pans taken off between two transmissions.
The 2nd and 3rd pictures are from the new transmission. The 1st and 4th are of the one out of the car.
Bzzzz wrong ;)
Different spline count
Boosthpy;1016839 said:
I guess everyone is as stumped as I am.
1 is an a340e the other is a 341 out of a Jz car.
tlo86
Jul 24, 2005
3,914
Colorado
IJ.;1016842 said:
Bzzzz wrong ;)
:biglaugh: i originally said i had no clue but i thought i had reused my turbo torque converter, i guess i got them mixed up and didnt notice
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
My AE340E is from a 90 supra with all options and has 4 plugs.
See if the old one has a rear speed sensor. A sensor on the tail shaft of the trans.
The Neutral Position sensor has 2 plugs and 1 plug is for over drive and the 4th plug is Rear speed.
