attn: 7m ebay manifold users
808mkiiisupra
The HOme OF the Grass Shacks
man you have a welded on elbow....if i could do that i would but thanks your pictures gave me other better ideas on other stuff. btw for your ps hoses did you reuse the stock high pressure side? and is it possible to use regular hoses and clamps for the high pressure side?
808mkiiisupra
IJ.;1173901 said:
I used to use a 90 degree silicone elbow there.
I modded the HP hose to fit and no it needs to be a proper high pressure assembly clamps won't work.
yea thats what i was thinking...i guess i have to make a custom line then....
does your piping go through the sheetmetal????
Goes out through the hole under the headlight, I made some rubber seals.
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
fark that mustve been along time ago.lol
And just letting you know im so copying your intercooler setup, i roughly have your intercooler clone just need to build pipes.
Yblegal91t
it finally runs!
Apr 22, 2006
331
C1 outer
perfect spot for the oil filter IMO.:evil2: looks great and nice welding on the pipes. you do that yourself Ian.
edit: my filter happens to be in the same spot
shaeff;1174063 said:
ROFLMAO!!! That's hilarious. :)
WhtMa71;1174142 said:
Took me a minute..
IJ what is this? http://ij.supramania.com/more45.jpg
It was a servo driven mixture control valve I made when I was running LPG that let me use the fuel map in the MoTeC
Yep I do 90% of my own work and just farm out the stuff I'm too lazy to do :)
grimreaper;1174156 said:
damn those picks should be censored, supra nudity! sooo CLEAN!
It's filthy at the moment :(
Poodles;1174251 said:
IJ wins the slight of hand trick :D
Watch the eyes not around the eyes but the eyes 10,9,8,<snap> you're under ;) Whenever you enter a political discussion you will cluck like a chicken!
