Article: GUIDE : Modifying side repeaters
supra90turbo
shaeff is FTMFW!
MA, 01440
I've just been using a heat gun with a couple flat head screwdrivers and razor blades handy.
With the heat gun you can monitor how close the plastic is to melting. I heat it until it gets glossy, then you can carefully pry the lens off the backing.
