Ark MFD (Multi Function Dash)
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
I think the best deal is to go with a stand alone ecu + a carputer
if you plan to stay oem ecu and just want a display get stack inc 8130
if you could find a good combo deal for geting both a standalone and display together as a package deal then go that route!
The reason i suggest a carputer is because it could link into your standalone ecu all the time and you could directly link your maps and tune on the spot on top of that you could also store movies music and other gadgets and toys to link to your carputer.
not only can you monitor your standalone but you could also plug your lc-2 into the serial port and monitor your wideband directly also.
I could brag nothing but good for a carputer as far as display and tools.
The only reason I have a display instead of a carputer is because i got a package deal standalone ecu + display new for 1600 and the display lets me select between maps and lock my ECU out with a security system!
