Are 86.5-88 and 89-92 hood shocks interchangable?
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
I was at a junk yard the other day and picked up a working set of hood shocks off of an 87T. There are no distinguishing marks so I'm guessing they are aftermarket. Anyways, when I get back and look at my 90T hood shocks (which are blown OEM Tokico's), I see that they bolt to the inner fender. The 87T's shocks simply snapped over little balls mounted on the inner fenders along with identical ones on the hood. I simply pulled on a little metal tab to release.
Also, the top of the 90T shocks seems to be identical as they're attached to little metal balls under the hood, but I can't find the release on the shock anywhere. Am I missing something? Are the ball mounts and shocks one piece on my 90T so I'll have to unscrew them completely out of the hood? Is there anyway to use these 87 hood shocks on my 90, or am I better off just sourcing the correct ones?
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
I'm pretty sure they are interchangeable, as long as you have the whole assembly from one or the other. Fenders and hoods are completely interchangeable. I thought it was weird too.
The places Ive seen to get replacement shocks have it listed for all years MkIII.
shaeff
Kurt is FTMFW x2!!!!
11
Around
When I bought aftermarket pieces from the parts store, I got the ones that pivot on the ball. They're better, in my opinion, as they're easier to remove so you can tie the hood at 90*. Makes working in the back of the engine bay much easier. ;)
shaeff
11
Around
I don't remember, LOL. It's been so long.
I'm fairly certain that there are bolt heads on there that are connected to the shock. Unbolt them. I'd link you to the EPC, but I'm at work, and cygnus is blocked. :(
