anyone using this turbo??
JamesB
mass
GT 42. Turb. Hous. A/R 1.22, Divided, 6 Bolt, Comp. Hous. A/R .6
[805138] $690.00
Click to enlarge
Turbine Wheel Compressor Wheel
Exducer diameter Mayor diameter Exducer diameter Mayor diameter
2.67" 3.22" 2.63" 3.89"
Turbine Housing Compressor Housing
A/R Div. / UnDiv. Discharge Inlet A/R Air Inlet
1.22 Divided 6 Bolt T451 .66 5.47"
This product was added to our catalog on Friday 17 March, 2006.
see my page to see what my cars all about so far. my goal is 800 hp any info on this turbo or one that you have had good results w would be helpfull. llooking to buy this week.
you can se it hear. http://partsexpressonline.com/shop/...d=212&osCsid=f7e05876a3f34d3202a26a046d488981
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
thats only a 66.8mm turbo, 800 crank will be very hard to achieve with that turbo, especially with that small turbine ar. If you're looking for 800 rwhp you'll have to go bigger. look at the 72mm size turbos if you want 800 rwhp. what are your mods so far?
JamesB
mass
my mods so far consist of.
1. crower forged connectiong rods. custom spec
2. forged wiseco pistons. custom spec.
3. forged crankshaft. custom spec.
4. clevitte 77 rod bearings.
5. ARP hardware on entire motor.
6. tms main caps
7. clevitte 77 thrust washers
8. block bored 3.2L + decked.
9. tms cyl head. stage 3
10. tms 2.0 metal hg
11. arp head studs
12. custom spec cams reground.
JamesB
mass
gilberjj said:
nice mods, i would go standalone, raise the revlimit a little, and get a 76mm turbo.
my plan was to build a decent block that i felt could withstnd a fair amount of power, and then research wich ems and turbo would work best for me, my goal is to get into the 800hp range with out sacraficing spool time. what turbo should i be looking at to have full boost/spool by 4300 rpm or so and acheive 800 hp w associated mods? i would like to have it orderd in the next few days, so any knowledgable info would be greatly apprecited. **** ordered motoc engine managment today.
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
I don't think there is such a turbo :dunno:
Zach
ECUMaster USA
Apr 6, 2005
375
TX
I'm guessing you didn't just drop $3k+ on a Motec if you can't even spell it.
Got any pictures of your motor for the unbeliever in me?
Also, somebody with the cash to fund a build such as the one you've suggested would probably not be trying to decide which ebay turbo will work best.
Not saying I can't be wrong, but it doesn't quite add up.
LMAO>>
1. forged crankshaft Stock crank is forged
2. crower forged connecting rods
3. clevitte 77 rod, main, thrust washers.NDC's in Clevite boxes
4.wiseco custome forged pistons Custom for the 3.2L?
5.decked bored block. 3.2 87mm pistons?
6.tms 2.0 hg
7.tms stage 3 hed. ebay.
8. hks cams
9. ARP head studs, mains,caps
