i need some help.
i am wondering if anyone has ever expirienced a failed/failing knock sensor on a 7MGE? what are your symptoms?
anyone know how to definitively diagnose a knock sensor?? (nothing in the tsrm)
i have this problem where the engine kinda boggs down in mid to upper RPM..
-its not the ACIS, verified and properly functioning..
-VAF checked with lab scope, ok
-TPS checked with lab scope, ok
-plugs wire cap and rotor new, oem plugs oem cap and rotor
-intake air temp and coolant temp sensor both checked with multimeter, ok
i believe the knock sensor is at fault, or the connection at the sensor is loose..
no check engine light on
no codes
from what i read, the only time a code would be set is if there was an open in the circuit..
so i ask, has anyone with a 7MGE, had a failing knock sensor and can enlighten me on:
A. a way to diagnose it..
B. symptoms? how the engine will drive with a bad knock signal?
thanks in advance
no codes
thanks in advance
