aftermarket coolant resevoir
NYsBlueMA
Evo+supra=3 cars
Sep 24, 2009
136
New York, New York, United States
hey people just bought a rediculously big intercooler moved some things around and got it to fit. Now my problem is my coolant resevoir sensor, can i just take it off or should i find and modify a tank? I think it doesnt affect the check engine light just trying to see whats been done.
te72
Classifieds Moderator
6,614
8
WHYoming
I have the same problem. The stock JZA70 intercooler is a bit bigger than the 7m one, so the coolant reservoir doesn't sit down on it's bracket quite like it used to. I'm gonna be relocating the battery for water/methanol injection eventually anyway, I'll more than likely move the coolant reservoir then as well. My advice? Fab one up, make some brackets, and shape it sorta rectangular, but short. Should fit... Just don't forget to make sure the stock birdcage light sensor still works. ;)
sai_supra1jz
Eat. Sleep. Boost.
Sep 12, 2008
171
CenCal, Ca
Ever since I swapped to the 1jz, I just never put the bracket back, and just tucked in the resorvoir. I recently upgraded to a big XS intercooler so I just have it sit on top of the intercooler with a bracket that holds the it and the IC.
NYsBlueMA
Evo+supra=3 cars
Sep 24, 2009
136
i did about the same but i gotta do a flush soon
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
You cant remove it, you have to have it unless you want to be dumping coolant out on the road and sucking up air into your system. You can custom make your own, just make sure it has the same overall volume as you need room for coolant to fill and empty in the reservoir.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
Jose at Kaizen just bent the tab and used the bolt hole right above the original to mount it when relocating my oil cooler because of the upgraded IC, and everything works like stock..
Miiike
Brampton
Does anybody know what the volume for the 1JZ reservoir is supposed to be? Mine is missing so I just want to make something else up to replace it, I just need to know how big to make it.
mk3tattoos
1,104
Bremerton, Wa
Just under a half gallon.
I have a big IC as well, had to bend the stock bracket and drilled a new hole so it would fit.
It would be cool to fab up a new one:)
te72
6,614
8
WHYoming
Does the volume really matter? I would think that as long as you have it as big or bigger than stock, half full of coolant, half full of air, you'd be ok?
Miiike
Brampton
I have no idea how big the stock one is for a jza70 though, when I bought my car it didn't have a reservoir there at all for some reason lol, I just went and grabbed one out of a Prelude at a junkyard today, it's really thin and fit behind the intercooler with not too much of a problem
You need about 700cc for a 7M, I ran a small aftermarket one here and it just had enough capacity to cope.
(was on the other side when it was a 7M)
nctexan
268
Houston
is that an LS3??!
te72
6,614
8
WHYoming
nctexan;1732079 said:
is that an LS3??!
More importantly, is that a fan behind your intercooler? Sorry, never really followed the build on that car much...
destrux
1,183
10
PA
I once used a quart oil bottle with a hole cut in the lid and a zip tie to hold the hose just off the bottom. Worked like a charm for 9 years on my last car. It was in the fender, out of sight.
I used the most expensive oil bottle I could find in the garbage can... Amsoil.
hvyman;1732362 said:
Ot but how do you do that with the links? Or is there a name for it so i can google it?
Just go to "advanced edit" highlight the text you want to make a link then click the link icon, copy/paste the page you want to link into the box and it's done!
te72
6,614
8
WHYoming
Classy, but I like the rat-rod mentality! :)
I see a lot of people using cans and waterbottles and such for overflow and and catch cans.
ls3 cressida with nos energy overflow.
