After market oil pan
VooDoo
Draggin ass on his build
Mar 20, 2008
342
Valdosta ,Ga
The machine shop called me today and he was asking if the factory oilpan was big enough to accommodate for a high hp motor. He said it seemed small. I am curious if there higher volume pans that you guys are using or are the stock ones able to handle it. I should be in the 550hp range on a 7mgte. Any advise would be appreciated.
shaeff
Kurt is FTMFW x2!!!!
11
Around
If I remember correctly, drjonez used to make larger capacity steel pans. Or you could try to source an uber rare Group A magnesium oil pan. Larger capacity, better baffling, all around awesomesauce.
Koenigturbo
1,336
Oxnard CA
I'm pretty sure their are alot of people running the stock oil pan that are over 550 h.p. He said it "seemed" small why would he say that with anything backing up his statement.
KevinM
Knowledge driven
Seattle, WA
As stated, most of us run larger oil coolers so there's some increased capacity.
Your other options are custom, or Group A:
(not sure whose pics these are)
bmoss85
Permanently Banned Scammer
Apr 14, 2007
1,026
clemmons, nc
I'm pretty sure you can buy sides to weld on to your oil pan to gain extra capacity. I think summit or jegs may sell them.
VooDoo
Mar 20, 2008
342
Valdosta ,Ga
I assume since he only builds race engines (drag, dirt, street) and has been in business for 40 years he would be right. I was glad to see when I went in there that he uses a torque plate. Said he wouldn't go without one. He is the one that told me to ask you guys what you think. He does deal with mostly American. I don't think that he was taking into consideration that I am running a larger romote oil filter and cooler.
