after market air filter fitment.
MattTerror
28
Ohio
I went ahead and purchased the filter and adapter. mounted everything along with an aluminium sheet i found in my garage that i cut and bent half circle over the new element. It's a nice day for a cruise. too bad i have to work. :(
Oct 11, 2005
3,822
26
Thousand Oaks, CA
Here is some food for thought, when I datalog intake temp on my stock air cleaner, I see that after 30 minutes of driving it can easily be 20+ degrees C higher than ambient, and in traffic can be 40C higher. The stock intake is well away from anything hot, so this was a puzzle. Well, the cause is simple enough, the AFM case picks up heat from the exhaust manifold and other hot items in its vicinity, and the air passing through the AFM then picks up the heat from the housing. Put you hand on the AFM after a decent drive. This is also a very good reason NOT to use a metal accordion tube replacement.
Rather than wasting your time replacing the air cleaner which as pointed out above is not much a restriction when clean, it may be much more useful to try insulating the AFM from engine heat instead.
Setsuko37;1851595 said:
well if u run the same cai set upi have ull gain about 14 but if your 7mgte probably like 18 or more
Are these dyno verified?
I highly doubt your gaining 14hp from an intake filter on a ge
Typhoon
208
ACT
But it FEELS and SOUNDS like 14hp, and I WANT to justify the expense!
I'd be surprised if a stock GE picked up 14hp with extractors.
57trimMKIII
Texas Supras' Slowest
Jul 14, 2010
133
DFW, TX
If anyone is looking for an adapter, I have one in the spare parts pile
Just pay the shipping costs and it's yours - PM me if you're interested.
Satan
Tampa
Been a K&N fan for a long time. Still have one in our daily beater. Went with the Amsoil recently (nanofiber sumthin'). There are air filter studies out there and the oiled ones (specifically K&N) ranked lowest. So, when spending $50 for a new filter, I went with the Amsoil, since it ranked much higher for the same cost...
Good luck!
Setsuko37
95
Canal Winchester ohio
well i also have the maf modded to richen fuel so maybe im also feeling gains from that, but mine is an actual cai ram intake lol their is a tube running from the front fog light whole all the way to my spectre filter. Tho i dont really run it unless its dark and cold out so maybe im just having super good conditions
Typhoon
208
ACT
You funny. Wanna buy a bridge?
