Aem Wide Band Reading
Northbaysupra
BAY AREA MKIII
Mar 19, 2010
135
Petaluma
Hey guess so i got my wide band couple days ago and had it installed.
My wide band reading are 14-15 on throttle and 18+ on deceleration ( with my foot off the throttle )
Any thought ?? what should i be at ? am i Lean Or rich ..
Northbaysupra
BAY AREA MKIII
Mar 19, 2010
135
Petaluma
ooohhhh . Why is it this lean .. It dosent make sense. 560cc injectors with Lexus mas air ?? t61 turbo?? this dosent make sense. now i am running the stock fuel pressure regulator could that be it ? or do i just need a piggy back that bad
Northbaysupra
BAY AREA MKIII
Mar 19, 2010
135
Petaluma
Yea i dont know what the fuel pressure is since its stock .. #$#%#** driftmotion hasnt sent me my new one yet !!
Is there any way i can adjust my fuel pressure with the stock shit ??
Northbaysupra
BAY AREA MKIII
Mar 19, 2010
135
Petaluma
dude thanks a million!! im running 5 pounds right now and was planning to turn it up tomorrow !!
Ill just wait till i get my Aeromotive AFPR . BTW how many pounds should i set it at when i get it .. I was told 40 does that sound right ??
There are a few variables you need to take into account, but 43psi with the Vacc line blocked is a good start point.
The way it is now I wouldn't let it come on boost at all as "incipient detonation" will kill the engine without you even knowing it's happening.
Northbaysupra
BAY AREA MKIII
Mar 19, 2010
135
Petaluma
what do u mean by vacc line blocked are you refuring to this?
I circled it in red
Devin LeBlanc
1,830
Las Vegas NV.
Im running 1200CC Injectors on E85 through a stock regulator. Im betting its something else. Hook up an external fuel pressure test gauge and watch it under throttle. The fuel pressure may be dropping due to a bad pump or kinked line
Another MkIII
697
Chicago
Thing to be careful of is fake Walbros. There were a lot of them coming out of China when I bought mine, so I got mine through Driftmotion so I know its authentic. I already had a Walbro 255 in the car when I bought it, but the previous owner couldn't verify that it was authentic, so it got replaced. But its only like $150ish for that pump, so its worth the upgrade. Better to have too much fuel than not enough.
-AM3
