Hello Supramania!
As the title says, I have a dilemna for reparation of my BHG.
I have a quotation for a good local shop, that I'm told it is trusty, and I have a good feeling with them.
This quotation is for top end + bottom end repair (machining, etc..), with OEM gaskets and Cometic MLS head gasket. This repair is a very big amount, that I couldn't easily afford (but with some effort, I could).
I know that machining only the top end with OEM only parts would cost half this big amount.
Here is the background and the foreground for this 7MGTE engine:
Background:
When I bought it it was 88000km, it was reworked and a dirty cheap shop helps me to swap it in place of my old weared 7MGTE. (I know by pulling appart crankcase and cam covers that he has been reworked).
I had a first BHG at 89500km, next to an unplugged hose..
Now this engine is 100000km, and has a second BHG next to the same unplugged hose..
Foreground:
Internals are stock but reworked, I don't plan to change turbo at the moment, just a piggyback + bigger injectors to run ethanol (E85).
I may want some more horses soon, but no more than 300 until I rework my automatic transmission.
Conlusion: What should I do?
- repair both top end and bottom end with OEM gaskets but a Cometic MLS headgasket for a big amount of money I can't easilly afford
- repair top end with OEM gaskets with half a big amount of money I can afford
I attach a poll to this topic, please vote I will be very happy if you may explain your advice in answear to this post
Update: I think I will get both top end and bottom end machined. Got new question in post 7 about Gasket Set
Regards,
Reynald
Background:
Foreground:
Regards,
Reynald
