Looks good. The way I was going to hook it up was hook up the 2 valve cover ports to a T fitting then to in port on the can and put the baffle side to the intake turbo side.
get man hands?jesse_rc1991;1985258 said:I guess I just need some pliers cause I cant grip the damn thing to unscrew from the lid with my hand. get some tomorrow at work then
Been running the same stainless pot scrubbers in mine for 10 years now, no issue.jesse_rc1991;1985860 said:ive been weary of running mesh but that's just through reading expirences of it breaking down. what if you try rubbing some oil on the O ring like an oil filter to make removal easier
yours didnt come with an Oring to seal the lower half, iyts inside the lid? mine did. Maybe you just cant see it cause its black.525gte;1985885 said:No oring. It's the threads. I put antiseez .
i guess i just wouldnt want that possibility of it happening thenIJ.;1985888 said:Been running the same stainless pot scrubbers in mine for 10 years now, no issue.
Nickle antiseize on the threads will help...
