Gah! If anyone has been following any of my threads, I finally got my car running after a rebuild. I hooked up my mechanical oil pressure gauge just now using the adapter to go to our blocks and ran copper hose all the way to my gauge. So I start it up and it goes up to about 40-45 psi at IDLE and I blipped the throttle and it went up to 60psi. I only shimmed the pump 3-4mm, other than that I have an aftermarket oil cooler but no changes to the setup really. Still the GTE filter housing running new lines to the oil cooler. At this rate I'll have about 348 psi of oil at WOT :icon_evil Any clues?? I'm stumped
-Chris
P.S. It's cheap 10w-40 (non-syn.) with an AC Delco filter I think?
-Chris
