92nsx's supra build
92nsx
2,957
Clearwater, MN
Well I have the lip ordered, it wasent to bad at all (I was expecting worse) $234 shipped new form toyota.
Now I just need to find the duct.
http://www.cygnusx1.net/Supra/Library/EPC/291220/catalog.aspx?F=4705&P=2
After ordering it I have been reading around I see they might be discontinued witch might just chap my ass because the lip will be pretty pointless (like the last one) to have the ducts cut into it. If any one has them or knows where I can find the ducts let me know.
Parts numbers so I can find them again if I need them
76851-14050 - 1990+ Supra front lip w/brake ducts (The JZA70 wasn't the only model that got it).
47791-14900 - Brake Duct Set (includes everything you need)
EDIT: Talking with adampecush, I think I might have the same problem with the dusts he was having (beside not being able to getthem, lol) The aftermarket intercooler and piping is in the way of the ducts. I will have to check it out when it gets here.
92nsx
2,957
Clearwater, MN
Well there Mr. Blue what did the UPS guy drop off today that you want to make your new bed?
A new rockford fosgate P2D412 from crutchfield subwoofer I see we have here.
Dam this thing is a little on the deep side, I hope it makes in into the box I have in the rear.
Out with the old and in with the new. Fits like a glove whoo! and sounds pretty danice with only 100 watts RMS going to it (maybe a little more now since the DVC is dropped down to 2 ohm :sarcasm:.
Now I have to make up my mind what amp I want to use. This kenwood, my alpine V-power (both only 50x2) or the MTX 81000D Mono amp that can run a small city. She has 8000 watts!!! and one of the best amps I have ever owned. Why the stopped making it I have no idea. The problem with the MTX it is a little over kill for a 250 watt sub, lol. That amp draws more then 150 amps at peak and our little 80 amp alternator might just go poof. Maybe time to call up DM for a new, higher alt.:evil2:
92nsx
2,957
Clearwater, MN
Today the Fex-Ex man dropped off a new privacy cover for the rear. It is pretty much mint! No more paint speckles or stains like my old one. Also got one hell of a good deal on it from Rich, thank you!!!
92nsx
2,957
Clearwater, MN
Ya it's pretty nice, even better that she is running strong. I try to take her out every day that the weather is nice :)
dslocal
340
slo
Ya because pretty soon your going to decide to do something else and it will be down for another 6 months
92nsx
2,957
Clearwater, MN
Yep your right. This winter she will sit on jack stands again to install the new turbo setup, and full flow oiling system.
slowmedown;1394085 said:
Great build car looks nice. I like the custom sub enclosure not sure why more people dont do that
Me either :dunno: , the one draw back to it is that it is a small enclosure but all you have to do is spend the money and buy the correct sub for the space you have. Like the P2 Im running, she is happy with a sealed box between .7 - 1 cu. ft. It could be made to look a lot cleaner or smother but it works good, and no one sees it under there anywhere. It also looks like I will be making another one for a local member.
92nsx
2,957
Clearwater, MN
WHOO ATI timing cover. Now time to grab a few beers and install. Lets see how dirty it gets. Maybe it will need some tint to her later on in life.
92nsx
2,957
Clearwater, MN
Well it is installed, not much to look at but I feel better knowing that there cover up and I can still keep a eye on the gears to make sure they dont slip.
92nsx
2,957
Clearwater, MN
:) it is like a cotton candy machine now lol.
I dont know why people say they fit like shit????? All I did was install the gasket and it fit just like the OEM, black one did. Is is worth the $120? I dont know but I have one now, lol.
92nsx
2,957
Clearwater, MN
Well I came home today and there was a HUGE box that said TOYOTA on it. The turbo R lip is here and looks really good. It will look perfect on my sup i feel. Now to find another storage spot for it tell I install it this winter and some used brake ducts.
LOL blue (the cat) had to check out the box. Once I opened it he had to jump in it and see how things were inside the box.
Supra28
Supramanian
Aug 17, 2006
1,921
Columbus, OH/Kansas
Clear timing cover looks good, hurry and put that lip on and take tons of pics!!
What's the new turbo setup going to be? If you don't wanna tell, I understand haha.
92nsx
2,957
Clearwater, MN
Igknyte;1399340 said:
how did you get your dash lighting to be like that?
anyways well loving the supra hopefully someday ill be able to do the same.
There just white leds. Just remove the cluster and and replace the light bulbs on the back of it with leds
I will get pics of it all in good time ;)
As for the turbo set up, right now I think Im just going to go with a t-70, with a (egay manifold and wg.) unless I find a good deal on another turbo before I pick it up. One can really beat the price on the t-70's. New, warrenty & shipped to your door for $600.
