9:1 compression + high boost
MRSUPRA
838
Maryland
Another thing not mentioned since we are going over un-mentioned things: Most new turbocharged cars use a much higher compression in there engines. The reason: Again, drivability. And of course better technology like Direct injection for better cylinder cooling allows a lower detanation threshhold.
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
Also the smaller the engine (cylinder with, sorry forgot how to speel the other with) normally is more forgiving towards detonation it is.
Doward
4,245
Alachua, FL
Actually, with a smaller bore (not necessarily the engine) and the same style combustion chambers, you'll have less chance of detonating with the smaller bore - the quicker you get the flame front propagated, the less chance of you having combustion where you don't want it :D
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
there is a local dsm running (que drum roll) 30 psi on pump gas w/out meth. I kid you not. he ran an 11.1 in steet form. kinda cool i thought.
zbaVR4
9
SB, CA
IJ. said:
It wasn't?
'responsive' and 'snappy' might not be as clear and concise, for others, as you might think it is. I could say my lawn mower was responsive and snappy but that doesn't describe if its turbo'd :)
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
U says it smrt :love:
Thats what i was trying to communicate.
Also... 30psi! WTF... stock flow! LOL
quake
toyota tech
Apr 13, 2005
619
r.i.
bigaaron said:
Another thing not mentioned is the you can make more power on pump gas with lower compression. What kind of gas are you going to run 99% of the time?
yeah your right. So i bumped the compression down a bit to 8:4:1, pulled the 71mm and put the ct back on for the mean time now looking for a 67.
Dec 3, 2003
6,653
Canada
LOL the only person in the rear view will be you :biglaugh: The only way I would be in the rear view is if I already had hit the brakes and you did the ricer fly bye LOL
quake
toyota tech
Apr 13, 2005
619
r.i.
lol
ozworldwide
4
banbury
Sorry but an engine is a engine just some are more efficant as a std engine before serious mods.
Think its just a fancy air pump
