89 toy truck, Rolling truck down hills are fun
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well i have mroe then one project
this is my other one i just about finished and the cage work but there still more to do lots more
lower my fuel cell down
re do my shock montes since i just swaped in new rear axle and spring perches
i plan to make anty wrap bar but not tell i take it out for it's frist test run
for the front stuff that i have to do is relocate my steering box and change up the front caster to make turning easier when i locked int he front end
and fi i find time i am going to be ditching the 22re for a ka24defor s13 wheil still useing the w56 trans
well here are so pic's
new 4 runner seats
new rear 4 runner rear axle whit cable based ebrake
axle parts
new trans tunnle for dual t cases had to be made since this is 2 wheel drive truck at one time
will be covered in stainless
cutting the back shit off sick of hitting trees with teh rear end going kinda for the the dove look but still have tire coverage
more cage work
well this is my truck :evil2:
shaeff
Kurt is FTMFW x2!!!!
11
Around
Pretty cool, Ryan. What kind of tube bender you using? I'm planning to get one next summer to make a tube bed for my Pickup since my bed is about rotted away.
shaeff
11
Around
Yeah man, they're sweet little trucks. I love my '94. :) I was going to put up a build thread as I'm doing a 7m swap but I delayed it until summer. Winter is right around the corner, and the truck has wintertime DD duty so I don't want to run into any issues. June is looking pretty good.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
tanks guys as for the trube bender iut reall depends if you going to use sc40 pipe or dome
half my truck is dome the back is sc 40 for extra weight
as for the bender k2 is a good bender
i thought about 7mge swap but really it pretty cramped in there and well i not fan of breaking drive trainin like twigs
i had a 3 slow befor that i mucked with got good amonte of power out of it tell the pinot evey wheeling trip i blew a rear end up grrrr but stilla great truck thou kinda missed it but to tipy and heavy
removed egr
removed emmsioes
felx alight fan
apexi neo
7mge afm
7mge coil
duag thory header
ajustbale fuel reg
m300 wide band
cuostom intake pipe
7mgte altanator
all that was leaft that is need was a set of cam shafts from colt cams
ps my 4runner did nto sound like 3 slow at all in any forum sounded pretty nice
so for now i going to stick wiht eh 22re and hold on my ka24de swap
yes tou herd me a dohc nissan motor 150 hp and 160 torq
but thsi is what my truck looks like right now not fully done or the latest pic's
had to add in some bling
NashMan
Aug 5, 2005
4,940
17
Victoria BC
been a wail for an up date but this what has been done
t cases done (say no to ramming and hello to crawl)
ps that stuiped lock out pin for the tiwn sticks, who the hell has magnetic punch that long ? I was going to go buy one but fuck it BFH time
so i used my brass hammer and pounded the other side of the cases tell it shook loose and fell out
WIN
truck got painted with good old paint brush gonna do the rest of the truck when i get waganer house painter gun
shaeff
11
Around
Sick. Action shots/video when you get around to it! :)
Obviously w/ the 22re you've got a gear driven transfer case, what gears and adapter did you use? Marlin? Trail Gear? And what ratio did you end up with? The 4.7's, or dual 2.28's?
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i use trail gear manily, marlin stuff is good and all but there stuff over priced and the same as tg (both have there ups and down)
as for gearing i useing dual 2.28 for around here that is nice gear setup to have since wheel speed means alot out here
plus i have 5.29's in my diffs
the 22r is going to be replaced with 1jz again for stuiped killer reliablity and able to stay on rev limter all day long
i gonna replace the stock tiwns with a stock ct26 to keep the power level down and save space
and if i go propain then i will need 2jzge head so i can run distributor
but that will be later date
shaeff
11
Around
Nice. I'm more of a "pick a good path" than "smash the truck 'til it gets up" type of driver anyway. I don't think I have a need for 4.7 gears so I was also considering dual stockers. I almost had an extra t-case for $30 a few days ago but the deal fell through. I'm still on 4:10 gears, which is why I considered the 4.7's.
Keep updating this, I love this stuff.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
it will be slow but i guess i can keep updateing it
what next to do is streeing box relocation and mabye re do my frotn hanger and lower it witch will fix my caster issu a bit
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i migth even pop in 3sgte might be cheeper option at this point as well just need to toy van bell very easy to find and cheep
the 1j to w58 i ned the 2jzge bell and fly wheeland is not that comon
but this what have been up to
NashMan
Aug 5, 2005
4,940
17
Victoria BC
got some stuff done
monted brakes line's
added diff armor
shifter plate thing use cv axle boots as shitfter bag nice and cheep and easy
and installed my light's
made my 4runner e brake cables worth witht eh truck e brake system
very much diffetn but i made them work wiht some cuttign weldding and all that junk
next is to make stinger and finshed wireig my truck lights and make drive shafts
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well truck is on the road not fully done but on the road
took it out and broke it too hahhaha and tested out my cage as well
2 end over enders and 2 barrle rolls tell a tree stopped me
damge big hole in my roof were rock ppunched though and bent rim and snapped a set of chevy 63's in half all 3 leasf
i guess a 200 foot high hand stand might do that and wrape then in to death
---------- Post added at 11:43 AM ---------- Previous post was at 11:40 AM ----------
---------- Post added at 11:44 AM ---------- Previous post was at 11:43 AM ----------
toyotavince
gear slammer
Jan 20, 2011
25
socal
damn you werent playing bout rollin into a tree. thats crazy, it a good thing you had that cage there. the trucks lookin good. i see a friend of your is running a propaing setup, nice.
and those trails your guys are smashing on are very nice as well. canada looks fresh.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
ya it's alot of fun
only thing that sucks abotu wheeling is you break stuff but my rig is pretty good now for not breaking
but i got bord today and made the NM power package
custom 5mge afm (bord swap)
87 to 88 7mgte thottle body swap 22re tps and re did the linkage
apexi sfac 2 if i can get it to work wiht this wacky scaleing
here some pic's
