LoL No problem man!! Glad to be of help
. What should happen is when ur keys are in and turned to on, all you have to do is turn the light switch till ur running lights are on, and then ur foglight switch should work. What I was told is you are basically removing the foglights from the headlight circuit, making them semi independant, and no ur defogger wont turn on the lights, ur just using the (I think) the 12volt source that the defogger has when the keys are turned. And I got my BVSV installed with no issues ^^ thanks for the tips!! I put thread sealant on it and screwed it in until I didn't think it could make another full 360 to the position where the 2 nozzles are pointed straight back (since I couldn't find any spec on torque, all it says in the tsrm is "install the BVSV") Hope it holds up =O... but now..........
more problems... I have isolated the strange noise to the bell-housing, and from what I read most ppl seem to think that it's the Torque converter. I don't have a clue how to really diagnose this myself, and the only other way I can think of is to take it in to a transmission shop, where no doubt it will cost me an arm and a leg to just diagnose, and then I will need to give up my remaining limbs for the the torque converter itself and the install (don't think I'm at the point where I can confidently remove the transmission and tinker around in there, especially since I don't have the tools required) And if it's not the torque converter, I still don't think the problem is going to be a cheap fix.
AND... after a prestone cleaner and 3-5 hours of cumulative driving in 2 days, I drained the cleaner and flushed... then did a Prestone flusher flush... and GUESS WHAT??? the water is still completely BROWN with no hint of clearing at all!!! is it normal for a 20+ yr old cooling system to be so freakin dirty????? *sigh ... tomorrow is superbowl sunday... I will not work on my car (but most likely I won't be able to resist) ... I'm gonna finish up my 3rd brakelight and start on the right side taillights. Still need to figure out what people are using to buff out sprayed on clearcoat for that amazing deep gloss... no matter how well I spray it I can't get away from fishscaling
---------- Post added at 11:26 PM ---------- Previous post was at 11:15 PM ----------
OK Pics of today's work
I think it'll look great once they are all done and clearcoated and polished, no?
Doesn't get much more broke than that...
10 bucks shipped off ebay, did the hot water test, and it worked awesome
yeah... put the sealant a little high oops... I went back and redid it after this was taken
so now all my piping is connected, not sure how much this will affect my performance, and I already passed emissions without it so... whatever it makes me feel better with everything connected the way it should be
I used BOTH... and followed the instructions to a TEE...
and it still looks like this... WTF
