87 RX7 sawblade stock wheels on the MK3?
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Anyone know if the Mazda RX7 wheels will fit on the MK3? I know they are the same bold pattern, but will they fit the mk3?
Rims are coming off of an mazda rx7 1987 turbo......... reason i want to buy them, is cuz theyre lighter than the sawblades.
Edit: What about the offset?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
what are the offsets of the RX7 wheels?
They'll likely fit though. There's so much room in the A70 wheel wells it's ridiculous .
Edit: just looked it up. FC wheels are 16x7 +40. Stock MKIII wheel is a 16x7 +35, so you're sitting in 5mm more. Not a problem.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
So 5mm more means theyll stick in a little more? Im a noob with the offset stuff.
The FC wheels are a newer style, im looking into the older 1987 turbo rx7 style rims. I really dont wanna have problems with turning or having to mod anything. Thanks
Clied
Wangan Supra
Jun 8, 2006
367
NorCal
I believe FD wheels are lighter then FC wheels if all your trying to do is lose unsprung weight. FD wheels may cost a bit more but they are wider and better looking then pizza cutters too. In my opinion the A70's sawblades look better then the FC's sawblades.
But it doesn't really matter since they both look ugly.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Yes.
What a +40 offst means is the mounting face of the wheel is spaced 40mm towards the outside of the wheel from the centerline, which will pull the wheel in.
The higher the offset, the more it tucks in. The lower the offset, the more it sticks out.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Speed said that the RX7 wheels he borrowed for his mk3 while his wheels were getting powdercoated didnt fit, but he didnt explain why. I'll see if I can find out why.
annoyingrob
Boosted member
Jul 5, 2006
2,304
oh, maybe the center bore is too small. I never thought of that.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Ok guys i just found out that those rx7 wheels weight 21 pounds lol.,, so nevemind, but thanks for the help guys.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
FC center hub is too small. If you have a 8mm spacer to clear the hub on the supra you can get it to work though.
I tried to use a RX7 convertible wheels and failed lol.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Yeah the RX7 convertible look like BBS Mesh style wheels, those look nice.
Forget it ill look into some other rims. Thanks guys...
