87-92 Block Differece 7m-gte
8,897
Well, the one who posted the pics of the later block also noted they have more core shift. So have the machinist check it if you rebuild. You can't sleeve it.
Doward
4,245
Alachua, FL
Late model blocks have stronger main webbing, extra rib bracing around the block, and 2-3mm more meat pretty much everywhere.
IJ. has pics.
shaeff
Kurt is FTMFW x2!!!!
11
Around
Here are IJ's pics, I have them uploaded in my Photobucket acct. Click to enlarge:
pre '90 block, thinner walls as mentioned, and less bracing:
'90+ block, with extra bracing/ribbing:
Tgood
All throttle no bottle
Dec 16, 2005
206
ennis/dfw
Actually you can sleeve a 7m block. I didn't think you could until one of my buddys did it to a 7m. He only had to sleeve one cylnder though. He sleeved it because the guy couldn't afford to buy another block so they sleeved the one cylnder.
Edit: forgot to mention that this motor wasn't going to be for a high hp application it was just a factory rebuild. The build thread is on here actually. Gtsfirefighter's block is sleeved and his motor was built by a guy that knows his stuff.
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
I actually could afford another block but opted not too because I couldn't find one in any better condition, that was local. The cost to sleeve that one cylinder was about the same as buying a bare block. After riding in a 2JZ TT powered MKIII the other day, I might be rethinking my power goals. My block should be good for whatever I might desire, which won't be that much.;)
My block is an 87 GTE BTW
8,897
You can't cut more than 2 thousandths off the block either, when in fact you can. So the idea that you can sleeve it is bad info being passed.
gtsfirefighter
Sep 26, 2006
2,966
DFW
I've got one sleeved cylinder and am only looking for 300 hp. We'll see how it holds up. It runs really well now but I've only driven it up and down the street a few times. x::crossesfingers::x
Tgood
Dec 16, 2005
206
ennis/dfw
Sorry ken I didn't mean to put you on the spot like that. I knew you couldn't hold out and not put some power down. Lol I plan to do somthing similar.
89whitepkg
I hate rust !
Mar 7, 2006
121
Lexington, KY
so, is the fact that I'm using an 88 block going to be a problem when I start trying to put down some serious numbers?
I'm not talking about the setup.....the only factor being considered in this question is 88 block vs 91 block, are there any extra steps that need taken?
j3pz;966404 said:
no the turbo models have the oil squirters.
Genuine Group A blocks have no squirters and are based on a Heavy NA block.
Check it very carefully for cracks in the deck, the above pic was an 87 with 18000 miles and had a bunch of cracks between the head bolt holes and the steam holes.
j3pz
still learning
when you say heavy, do you mean one with more ribs/bracing? wonder why they didnt use any squirters.
do you mean 180,000 or 18k?
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
I remember reading somewhere that there is a possibility for the squirter's to fail resulting in a loss of oil pressure?
Someone correct me if I'm wrong.
The squirters function at ~40 psi...if one or more stick open, yes you will have a loss of pressure.
The NA blocks went to the heavier/thicker casting before the GTE blocks did.
It's only a guess on my part but I'm assuming they placed a higher priority on more Oil volume to the bearings than in keeping the engine cool, they ran fully grooved mains as well.
18K as in eighteen thousand miles so barely ran in ;)
TurboWarrior
Canada
oil squirters were on late model turbos. either 90+ or 89+. They werent on 87-88 turbos I know that much. My motor is a 7mgte rebuilt there were no squirters when i took it apart.
