8 speaker stereo?
Mk3runner
2,033
Nor Cal
so this is what the stock setup looks like.. I never cleaned the hatch so please forgive the appearance.
thedave925
Since 9/16/05
Nov 9, 2005
626
East Bay, Cali
How I cleaned my carpet:
hang the carpet by a clothes line
spray it dripping wet with pure pinesol, maybe twice even
take your garden hose and attach your favorite spray gun
spray side to side from top to bottom
air dry a day or two.
Adjuster
I like my sub better. :) Takes up less space too, and it has a custom grille... :)
I have 4" Diamond mids in the door, and tweeters in the panel..
Same with the back. (If I was to do this again, I'd go with new door panels, and larger speakers in the door, same tweeter setup, and 5.25's in the back panels with tweeters mounted up the same, to reflect off the quarter glass..)
Oct 11, 2005
3,821
26
Thousand Oaks, CA
Adjuster, the back enclosures are pretty much 5.25" wide at the speaker opening, with about 2.75inch depth. Do you think the Diamond D651i 5.25" would fit?
I've got two spare enclosures that I was going to mill out to try and fit them, but if you have prior experience please let us know. Otherwise, I was going to order the Diamond D641i as they will definitely fit.
Supra469
495
Maryland
Is it possible to see a pic of how this sits in the hatch. I sure would't mind getting one of those for a stock location to add a sub.
Can it be opened up to replace the woofers?
What's that part number?
Thanks.
