7MGTE re-assembly
supramk3speed
305
Texas
Thanks Jdub, i like your answer. For me and lowtaco (you will want to know this for sure lowtaco) how is it suggested to prepare the deck surface on the block, i heard that u DON'T sand it to get it as smooth as possible i actually heard that on the deck surface on the block ( not talking about the head, head requires machining) that u just use a gasket scraper and get all the gasket surface off and that would be good. Is that true?
The block deck needs to be machined for a MHG, just like the head. Or, it can be hand lapped with the motor in the car using a lapping plate and diamond paste. If you scrape the old HG off and that's it...use a OEM HG. I would never sand the block deck...if you do, there is a very high probability that "hills & valleys" will be induced.
paradox616
472
Melbourne, Australia
+1
if you can't ensure a perfect surface you shouldn't fit a MHG,
lowtaco
282
Under a damn Toyota
92nsx;1391095 said:
No need for all the extra fuel and what not for 300 ;) Many members are just running higher boost on the ct-26, intake and 3" exhaust/dp and are making 300+ on stock fuel / clutch. Kind of like me. If anything I need to take fuel OUT. Im running under 10 as soon as I see boost.
Really?! Might hold off then considering money is tight. As far as my head gasket/studs go, I used the OEM Toyota gasket and new head bolts. OEM gaskets fail under higher boost/detonation, so I'll keep it at a moderate boost level and make sure I get a AF sensor to moniter things.
Also, got the engine completley back together just waiting for some $$$ for a clutch then the car should be going again.
Nghty89
Zombie Chicks Are Hot
Mar 26, 2008
978
7 Cities, VA
Too bad soundslikesemi87 hasn't commented on this thread yet. He's running a stock HG, and properly torqued head bolts @ 15-18psi. That car made me want to piss myself when he put his foot into it :biglaugh:
Yep...a properly tuned motor will run all day at those boost levels. You have to be careful though, you detonate at all and it's done.
Personally, I'd drop it down a bit (safety margin) and be happy ;)
lowtaco
282
Under a damn Toyota
I know the 2RZ Tacoma engines will handle up to 15psi properly tuned. Not real sure what the gasket material is tho. 15-18 psi? How many foot pounds you torquing them to?
92nsx
2,957
Clearwater, MN
lowtaco;1409666 said:
Really?! Might hold off then considering money is tight....
YEP. In fact here is the dyno sheet on 100% OEM electronics, fuel system and turbo (and still to need to take fuel out). And If I would take the 272 cams and reinstall the factory turbo cams the HP #'s would be considerably higher ;) 272 dont like low boost.
The A/F ratio is on the bottom of the sheet. Well under 10 as soon as boost comes on. Boost levels are 10-11 lbs on oem CT-26
Dyno sheets dont lie so here it is
lowtaco
282
Under a damn Toyota
Awesome numbers!! I cant belive thats just with more boost. No other mods at all, intake, exhaust?
lowtaco
282
Under a damn Toyota
Insert random cussing.... I installed the exhaust mani last night and the previously installed heli-coils on two of the studs pulled out:3d_frown:
No biggy but everytime I get a step ahead somthing sets me back.
Also does anyone have any factory injectors laying around that are close to Ky??
lowtaco
282
Under a damn Toyota
New pic! Ive got alot more done since this one. Everything is back on except the CPS and the injectors. Ive finally got my OEM clutch cant wait to get this thing running again, Ive never even driven a Supra.
suprarich
Guest
Nov 9, 2005
2,187
ohio
jdub;1391363 said:
The HKS does require a lower RA spec though.
John - Lets just say that hks WANTS you to have a lower ra spec and it has never really been proven that the lower ra spec is absolutly needed. Conversly, it has never been proven that the cometic is more forgiving to ra spec,,,only that they do not ask for as low an ra spec as HKS. Both gaskets could very well have identical sealing properties at the exact same ra spec.
ATL88Supra
The Asshole
Jun 22, 2007
497
Atlanta, Georgia, United States
swaq;1384669 said:
You might be interested in reading this thread, sounds like you have similar goals. A stock head gasket should be fine for under 10 psi, but I don't think you're going to hit 300 hp with just that...
This is incorrect, a stock headgasket will handle 15 PSI(max psi on a stock ct-26 any more then 15 and you are just blowing hot air) if the head and block is preped correctly.
gaboonviper85
3,236
Northeast Philly
you go ahead and push it too 15psi on a stock hg...the rest of us would rather not.
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
hmmm, well, I won't recommend running high boost with the stock gasket with unknown history (torque specs) but my car has over 20000 miles on it running 12-14 lbs, the car fuel cuts right around 14-15 lbs, on the stock head gasket. I can monitor AFR's though to help make sure it will not be likely to detonate (as well as using my ears). It is widely accepted that the OEM gasket is fine up to around the 300 rwhp but at that point it becomes more succeptable to failure from detonation. Detonation will kill it in short order.
Rather than tell everyone that the OEM gasket sucks maybe you should get your turbo car running and then spread some advice from experience...good luck on your build though, it is looking good.
lowtaco
282
Under a damn Toyota
I just got a CPS and injectors, still waiting on a air flow sensor. But everything is going good, Im going to get the engine set back in this weekend if the rain lets up.
Is it recommended to re-torque head bolts after a few heat cycles on these engines?
ATL88Supra
The Asshole
Jun 22, 2007
497
YES if you use ARP hardware STUDS OR BOLTS 500 miles or 3 or 4 heat cycles , repeat till you reach 500 miles, play it safe do it right! 75 to 80 pounds 80 should be the max
also know i recheck my studs every year in the 1st months of summer
