Will this work with the 7mge???????????? are they the same????????????
S supradan22 NA->TER May 20, 2005 915 0 16 ORLANDO FL Aug 29, 2005 #1 Will this work with the 7mge???????????? are they the same????????????
lagged 1991 1JZ Mar 30, 2005 2,616 0 0 40 new rochelle Aug 29, 2005 #2 the drive gear is different. thats all.
M mkIIIman089 Supramania Contributor Mar 30, 2005 3,061 0 36 Ohio Aug 29, 2005 #3 I hope you're not trying to re-use a GTE pump in a GE car... just asking for trouble with a pre-worn pump I think...
I IJ. Grumpy Old Man Mar 30, 2005 38,728 1 0 64 I come from a land down under Aug 29, 2005 #4 GE/GTE pumps will interchange for an NA using a GTE pump it is equal to a Hi Volume pump as the GTE gears are longer than the GE gears. No reason why it would be a bad idea unless it's a badly worn GTE pump.
S supradan22 NA->TER May 20, 2005 915 0 16 ORLANDO FL Aug 30, 2005 #5 I just want too no if it would work Ok cause ive seen the 7mgte Oil pump in ebay and I wanted too now if it was ok too buy it
shaeff Kurt is FTMFW x2!!!! Staff member Super Moderator Mar 30, 2005 10,592 11 38 Around Aug 30, 2005 #7 yeah, i'd go with a new one. it's really not that expensive. and its good insurance. -shaeff
