7MGTE Ignition Upgrades MSD DIS-4 Plus or HKS Twin Power
al lewis
100
dominica
Hey guys jus looking for some info on the two tryna decide which one to go with i don't know if this topic has been covered before if so please direct to the right section please. So far i've read that the MSD's tend to crap up and i havent really seen anyone running this system on their 7MGTE so please advise pro's and con's of using this system. Thanks guys.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
an alternative is to use 2JZ-GE VVTi coils, they're basically plug and play after you extend the harness..
here's a thread on it..
http://www.supramania.com/forums/sh...on-mod-w-stock-electronics...pics-and-writeup
I'm running these and love it..!
really helps clean up the engine bay, too..
attachment.php
al lewis
100
dominica
yea i saw that thread but would really like information on the aftermarket ignition systems as i stated above if anyone is running them and what do they find in terms of performance and worth.
TheNewRed
572
WA
The MSD setup is very strenuous on the factory coils, they cant handle it, and they probably will fail soon after the install, if it will even start with the MSD. It does have the 2 step feature, that the HKS dosent have.
Does anyone know if the MSD will support the 2JZ coil upgrade. You would need two MSDs wouldnt you, or is the 2jz coil setup still waste spark?
al lewis
100
dominica
even the low output version since they offer two theres a high output and a low output. Would the low output still be strenous on the stock coils if so would the HKS Twin Fire be a better option and what good two steps/rev limiters are there on the market? because i really like this feature.
TheNewRed
572
WA
You would have to use a DIS box to get a 2-step, without going standalone. I dont know of any recent use of the "Bee-R", but from what i have seen no one has used it on a 7M.
I suppose the low output would be easier on the coils, is that the one with the dip switches instead of the rotary dials?
al lewis
100
dominica
No it has the rotary dials, but really do you think i should install this cause i definitely dont want to blow my coils or should i just go with the HKS Twin Power Ignition System and call it a day? So thers really no 2 Steps i can use without going stand alone?
JesseH
1,153
Englewood, Ohio, United States
:wavey:
Ran a pair of Dis4's a few years back, quality control at MSD is somewhat lacking one failed in weeks, I was using their CDI 480v coils so running it in bypass didn't "work" and had to limp home on 3 cylinders.
8,900
For what reason?
HKS_TRD
998
Australia
My Brother and a friend have been running MSD DIS-4 with no ill effects on the stock coils
I will agree with Ian the quality control on the MSD is not that great
The HKS Twin power is much easier to install, and it seems no one is really certain how it works, but my old one did cure a misfire on a Nissan RB
