7m wont start! No crank or click...
mk3_dude
Boost Master
May 10, 2005
265
Arkansas
***EDITED****
I found out the problem. The Previous Owner Hacked the Ignition key, so he wired the starter pwr cable straight to a switch that hides way below the steering collumn and none of the wires were hooked up. I assumed it was that, and it crank'd!
---Now the problem....The car Is not turning over. It cranks and cranks, then it makes a loud Grinding noise after i crank the motor for a while. Sounds like starter/flywheel grind (somewhat to that affect). I sprayed starter fluid in, the motor cant even catch to turn it over. So i know its not a fuel problem....any Guest????
Over-view:
car cranks, but wont turn over.
Grinding noise if i crank it for a while
thanks guys!
shaeff
Kurt is FTMFW x2!!!!
11
Around
sounds like a dead battery to me. check it with a voltmeter.
mk3_dude
Boost Master
May 10, 2005
265
Arkansas
Battery is fine. I took the battery off of my Cressida and starts it up just fine. Which makes me to believe its my starter?
suprafanatic
1,607
Greenwood, IN
hey man.. make sure the fuel lines going up above the fuel pump didnt get kinked or pinched when you put the tank back up.. mine had the same problem
mk3_dude
Boost Master
May 10, 2005
265
Arkansas
now the problem....The car Is not turning over. It cranks and cranks, then it makes a loud Grinding noise. Sounds like starter/flywheel grind (somewhat to that affect). I sprayed starter fluid in, the motor cant even catch to turn it over. So i know its not a fuel problem....any Guest????
mk3_dude
Boost Master
May 10, 2005
265
Arkansas
Yes, kuv yog hmoon Lis.
I dont thing its the starter though. Im just going to re-do my wiring harness and see what happens. Cause its not making that noise no more.
