Stock 7m Intake(over the top) vs aftermarket or modded FFI (front facing intake)  which is better and why?  i see on www.7mpower.com that the ported stock manifold was on the #1 of the top ten...  whats up with that??
			MRSUPRA said:The stock manifold has been proven to flow very well. Will Neely made 684rwhp (all boost) on a T66 with it. The 3 main advantages of a FF manifold are: Less heat soak on the piping, improved throttle response(shorter piping), and a cleaner look to the engine bay. But for all out power, I don't beleive a FF manifold will help much over the stock design.
I wonder if the response problem has to do with people using intercoolers that are designed for a FF manifold. I bet that 180 degree intercooler bend coming off of the right endtank causes a lot of pressure drop. Hmmm.
Nick M said:If you dont plan on racing competetively and need every ounce of power why bother with fabrication. The Cartech unit flows way better and cools much better than stock. And it is about 800 less than HKS and Greddy.
I understand "cleaning up" the engine bay, it just isnt worth the work to me.
At the CFM most guys are running 3" is too big a drop in gas speed for me coupled with the extra volume may be responsible for the perceived slow response.figgie said:well it depends
all this is, for not if the total volume of the IC piping is the same as stock or even more.
How can it be the same or more?
bigger pipes (using 3 inch pipe throughout the IC system) increase volume area fast.
joel w. said:Xman, improved throttle responce? is that just because the ffim is less pipe than the 9ft of ic pipe required on the 7m type manifold piping, I measured it once for the shock value... Or could it have been the manifold? pretending the ic pipes were the same length...
hope you guys dont mind me asking, like to hear your oppinions..
i definately like the ffim look... way clean and shorter.. kinda beed answered i guess..
thanks much..
CryoSLash said:side note. how did will neely get his engien bay to look so clean. i love his.
