7M-GTE Ignition Upgrade
I have a brand new Dis4 in it's box here that I'll sell for half price if anyone is interested. (These things will fire the plugs under water)
$270 Shipped.
Drop me a PM if anyone wants it!
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
$270 Shipped.
This is a tech thread, please keep that stuff out. We have a for sale section, I'll gladly hold your hand and walk you over to it :biglaugh:
JUST KIDDING :icon_razz
kwnate
Lurker
Jul 10, 2005
2,725
mk3ukr said:
AEM CDI won't work with stock ECU (you will not be able to start motor). In fact most of CDI AEM produced failed. I ran mine for about 300 miles then noticed strange behaviour - like missing spark on idle and light load. Bypassed CDI and it works better. I don't want it to fail at high speed when overcoming other car.
AEM still didn't fixed this problem, even newest Twin Fire not perfect yet
I'm not running a stock ECU, I was told that the earlier problems have been ironed out. I guesss we will see...
MA70witBoost
Registered Drifter
Well, my goal at the moment is just to put as many bolt on's as possible, then get it running and take it to titan motorsports to have the emanage installed/tuned. Everything in the engine bay will be after marked (so i have planned) excepts for the 7M-GTE w/ will be running on stock internals. Looking to make around 400rwhp... maybe 500. I just want dont want any problems later down the road...
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
might want to look at forged internals then, if you want a reliable and fast car.
MA70witBoost
Registered Drifter
even if i have my wastegate shimmed at 10psi and the cars tuned? I dont intend on increasing boost past 10psi for now... Just to have the supra as a quick daily. Later when I got the money to buy the internals, then i'll park it, build up the motor, throw a boost controler on it and id imagine im good to go...
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
Id at least look into some new pistons (IJ had a good deal going) and some new bearings.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
i wouldnt trust stock over 400whp with stock pistons that are old and tired. something tells me that you wont see 400 on only 10psi as well, at least on a ct26, not upgraded.
Oct 11, 2005
3,822
27
Thousand Oaks, CA
While copper has a much lower melting point that Pt or Ir, it also has a higher thermal conductivity. Hard to say whether the better thermal conductivity would offset the lower melting point. A Cu/Pt/Ir alloy would probably have the best of both worlds.
Melting points:
Copper: 1085 degC
Platinum: 1769 degC
Iridium: 2446 degC
Thermal Conductivity:
Cu: 401 W·m−1·K−1
Pt:71.6 W·m−1·K−
Ir 147 W·m−1·K−1
MA70witBoost
Registered Drifter
so autolite copper as opposed to the NGK Iridiums? I was hoping on being able to have a reliable 7M w/o having to throw the rediculously large amounts of money required to upgrade the bottom end. Shoot, engine interals are expensive. Not to mention Im still a noob when it comes to engine internals so i wouldn't know really what to get. I've been looking around at prices ever since the forged internal thing got brought up and Suprastore has a what looks like a decent block package (IMO) but its a bit pricey at $1,595 for just Eagle Connecting Rods, CP .20 over size Pistons, Custom piston rings, Clevite 77 Bearing kit which includes the trust washer, Rod and Main bearings. And sadly i doubt the money will stop there.
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
What are your goals, there are people running 10 sec on stock rods shot peened! The bottom end is already over engineered from the factory, just replace pistons/rings bearings, shot peen the rods and have it balanced.
MA70witBoost
Registered Drifter
Well im not sure what i want the car for yet... I want it as a daily for a while... but to live up to the supra name.... in other words, i want a fast daily. Not looking to set any track records but atleast would like to run low 11's. The head gasket went on my motor. It had an HKS 1.2mm MHG, ARP Head Studs and the head was Port & Polished... I had originally planned on replacing everything on the motor w/ a bolt on, break in the motor, go to titan motorsports (im in miami, they are in orlando) and have them install my emanage and tune it and leave the wastegate shimmed at 10psi till i could afford to park the car again and do a performance rebuild on the motor and install an ebc... go all out (trailer queen)
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
If you had a BHG with hks metal and arp studs, you prob have a warped head or bad surfacing on head/block, you need them machined. You can get in the 13's with a ct, 11's will take a good bit of work, good luck with your project!
